Old 06-03-2016, 02:35 PM   #1
phillips's Avatar
Question for the WDH experts
I'm running the Reese Dual Cam WDH. I need to get more weight transfer to the front of my TV but I'm already running the minimum required 5 links under tension. I also have my hitch tilted to the furthest setting towards the TT. Is there anything else I can do to get more weight to the front of TV? The reason I'm asking is that my TV seems to want to wonder ocasionly in the front, I'm assuming this is caused by not enough weight transfer to front. Cpl pics of my current set up.
TV is a 2016 F150 long box 3.5 Eco with max tow.
TT is a 2016 Coachmen Apex 300bhs.
Sent from my SM-G900W8 using Tapatalk
current TV-2016 F-150 3.5 Ecoboost Max Tow
current TT-2016 Apex 300BHS
Reese Dual Cam WDH
phillips is offline   Reply With Quote
Old 06-03-2016, 02:37 PM   #2
phillips's Avatar
Reese Dual Cam WDH
Old 06-03-2016, 02:39 PM   #3
phillips's Avatar
Should also mention I have a 2" leveling kit installed on the front of TV, hoping this isn't my issue!! Also would air bags help with this issue?
Reese Dual Cam WDH
Old 06-03-2016, 03:00 PM   #4
Professional Curmudgeon
wrvond's Avatar
Air bags are not going to shift any weight, they will only lift the rear up. Lifting the rear would also cause you to have to shorten your chains.
It looks to me like you have some pretty stiff bars on there already, so either you have a seriously heavy tongue, or you aren't starting out with the ball and coupler the same height.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 06-03-2016, 03:01 PM   #5
Cinch it up to 4 links instead of 5.
Old 06-03-2016, 03:08 PM   #6
phillips's Avatar
Thats what I wanted to do but everything I read says make sure you have no less then 5 links under tension. Do you have any experience or known of anyone running 4 links with the dual cam?
Reese Dual Cam WDH
Old 06-03-2016, 03:22 PM   #7
If 5 links is the minimum, then you will have to tilt the head more toward the trailer.
Old 06-03-2016, 03:24 PM   #8
phillips's Avatar
It's tilted as far down towards the TT now ad it can. Would higher rated spring bars be a possible fix?
Reese Dual Cam WDH
Old 06-03-2016, 03:34 PM   #9
Doesn`t look like your reese head tips back as far as mine does . Maybe because your is a lot newer. Bought mine new in 2000. Will be putting into service again soon . Going to swap my Equalizer out and they the reese . As far as helping you I think the head should tip back more giving you more tension on your bars.
Big Red and 30WR is offline   Reply With Quote
Old 06-03-2016, 03:37 PM   #10
phillips's Avatar
Not a great pic but this the adjustment thing that came with the hitch. It's currently set to 6/1 wich gives it the most tilt.
Reese Dual Cam WDH
