Old 03-01-2012, 04:23 PM   #1
question for those with hitch rails in their 10+ dodge ram
i just got a 12 2500 dodge. i was wondering if anyone could give me some advice on which installation kit they used when installing their 5th wheel hitch rails. no-drill application would be a PLUS!
2006 Cherokee Wolfpack 295WP - 2 Interstate U2200 6v, 1500w inverter, clear lens LED clearance and tails, Starlight Revolution 300 lumen LEDs EVERYWHERE!
2012 Dodge 2500 - deleted and tuned by H&S performance
Bocephus is offline   Reply With Quote
Old 03-01-2012, 04:44 PM   #2
Witch Doctor's Avatar
I have never heard of rails of a hitch that did not have to be bolted to the frame, I do not know how you can do it unless you welded it to the bed. As for the rails it would depend on the model, but like I said I have never seen that app. only bolted, but things change daily, If you find some way please let me know.......Good Luck
Old 03-01-2012, 04:47 PM   #3
Nigels's Avatar
The type of hitch you decide on will determine which rails, allthough most hitches will fit universal rails. I am not aware of any rails that do not require drilling
Nigel & Bev
Brit Driver & Canadian Naviguesser
2011 Rockwood Signature Ultra Lite 8280ws
2011 Dodge Ram 3500 4x4 Diesel
Nigels is offline   Reply With Quote
Old 03-01-2012, 05:49 PM   #4
i know they have to be bolted to the frame... but i know there are some turn-over-ball hitches that are fastened to factory holes in the frame. i just helped my dad put one in his power stroke and all the holes needed were already there.....just had to drill the big hole in the floor of the bed
and i have also seen that most rails are universal. i have a reese hitch that was used in my last pickup, and ill be used again in the new dodge. i just need to get the rail system in the bed....
Old 03-01-2012, 06:43 PM   #5
alageezer's Avatar
The no drill mounts on the newer Rams use U-bolts rather than drill new holes in the frame. They still have to drill thru the bed The folks who installed mine used the no drill mounts with Curt universal rails to mount the B&W Patriot I bought on line
2012 Signature 8285WS
2010 Ram 2500 w/Cummins
alageezer is offline   Reply With Quote
Old 03-01-2012, 06:56 PM   #6
b1b1das's Avatar
I was told by the dealer, if you drill into the frame of the newer dodges (box frame) it will void the factory warranty. Mine is 2011.
I went with the B&W turn-over-ball and the companion fifth wheel hitch. Keeps the bed free and clear when not in use. They also offer slider hitches for the turn-over-ball. They are not made by B&W though.
2012 Stealth RG3210
2011 Dodge Ram 2500 Mega Cab Laramie 4x4
2010 Ford F150 Super Crew Lariat 4x4
b1b1das is offline   Reply With Quote
