Old 02-10-2015, 02:54 PM   #1
mlangdn's Avatar
Question on WDH Setup
I just bought a 2013 F250 6.7 and I will have to redo the setup. I was pulling with an F150. I have watched several videos on youtube and read till my eyes hurt, so I believe I'm ready.
Now for the question:
This is supposed to be done on level ground. However, my driveway slopes a bit. This slope is about 4" in 80'. So one knows its not severe. Is it the same thing as level to make sure the trailer frame is equal from the ground on both ends? The truck will be sitting the same and the measurements from the ground on front and back would not be different on level ground.
Oh yea, its a concrete driveway completely flat.
2014 Coachmen Catalina
243RBS 50th Anniversary
2013 F250 Lariat 6.7 Powerstroke
mlangdn is offline   Reply With Quote
Old 02-10-2015, 03:10 PM   #2
Yes you will be fine to set it up on a slope,besides you are in KY. you would have to drive a Long way to find Level ground! Youroo!!
Old 02-10-2015, 03:33 PM   #3
Yes it is the same thing (close enough) to be equal measurements. Besides it is hard to find a truly level surface anyway. A few inches one way or the other over that distance will not factor in.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 02-10-2015, 04:00 PM   #4
mlangdn's Avatar
Thanks guys!
Old 02-11-2015, 11:47 AM   #5
The easiest way is to measure the height of the frame rail between the axles. this are is almost a constant height regardless of slope.
jturnbull is offline   Reply With Quote
Old 02-11-2015, 02:38 PM   #6
mlangdn's Avatar
Well that makes sense jturnbull! Thanks!
