04-02-2016, 12:09 PM
Out of Order
Question regarding 5th wheel pin weight
Does the entire pin weight of a fifth wheel count towards payload in the tow vehicle? I'm assuming so since it seems logical that the pin weight is carried in the bed of the truck. Just looking around for fun I see that my F 250 can tow most popular 5th wheels in terms of max towing and GCVWR but the pin weights are near or at my max payload. BTW, totally happy with our TT but always looking to get educated.
Thanks!
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
04-02-2016, 12:12 PM
I'm the dummy/novice on this...........but this is the VERY reason that I traded for a Dually in advance of ordering our 5er. I had towing capacity with the 3/4 ton, but it had payload of 2,286 and my pin weight unloaded will be 2,407, and more loaded. I was over the limit before I started. Luckily, I got a great deal on a Dually........but it is Payload that made my decision.
FROG AR-0019-242
04-02-2016, 12:44 PM
I just went thru all the calculations on my truck to choose a 5th wheel. Yes, the entire pin wt. must be calculated, plus the wt. of the hitch and a percentage of any gear you might add to the coach. there is a sticker on your left door jamb giving you the rear gross axel weight rating. Have the rear axel weighed at a Cat scale or a recycling center. Subtract the actual wt. from the GAWR of the rear axel. The difference is what you can safely carry. I hope this helps , see you on the road!
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
04-02-2016, 02:22 PM
Yes, the entire pin weight factors towards payload.
04-02-2016, 02:55 PM
Great job doing the math and dispelling the myth that is truck manufacturers marketing. As long as the trailer is properly loaded, TV payload will pretty much always be the limiting factor...at least with SRW trucks...I've never bothered with doing the math on a dually as personally, I would sooner get a smaller trailer.
Side note...Why don't they make a dually where the axle is narrower and all four tires fit in the standard width bed? I realize the space between the wheelhouses would be reduced, but I am pretty sure there would still be plenty of room for a 5th wheel hitch. I would consider this option long before buying one the way they build them now.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2021 Solitude 310GK w/FBP
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
04-02-2016, 04:04 PM
Years ago Chevy made a one-off dually that way. Sure reduced bed space, but it would fit in a standard garage. Must not have generated enough interest they did not make them.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
04-02-2016, 04:06 PM
Part of the added stability of a dually is the wider stance. Narrowing it to fit in the fenders would bring you back to the same functionality of a SRW 1 ton. The limit difference between the two is the total tire capacity of 4 versus 2 tires.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
04-03-2016, 12:26 PM
There are many 5ers with pin weights from 1200# - 1700# just as there are some at twice that. Since you own the truck look around and you should be able to find what you want.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
04-03-2016, 12:31 PM
Blog: RVroadtripper.com
As previously said, entire pin weight goes against payload. Another caution has to do with equipment adds. Your 3/4 ton will have a posted payload in the door jam of the truck but that will be reduced for the following: side steps added aftermarket, airbags, total hitch (if it's 2 parts, add both), bed cover, bed liner.
Best way to get the true Payload is to go to a CAT scale and weigh the truck with all your stuff in it. Look at the door jam GVWR (my 2500 is 10,000). Subtract your CAT score from the GVWR and that's your remaining Payload for the trailer.
Now when shopping for the 5er, remember the mfg published pin weight doesn't include the 60# battery and the dual 45# propane tanks.
Some experienced towers compare their payload numbers to whats available for the truck's published rear axle and tires. For instance, my truck's GVWR is 10,000 but the GWR for the front axle plus the rear axle is 11,200. My rig fully loaded is about 1,000 below the Rear rating but almost exactly on the GVWR rating.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
04-03-2016, 02:38 PM
Adding all the axles is how ALL other highway trucks are calculated on any scales, or road checks. My straight 3 axle farm has a 12,000 + 2 - 20,000 axles = GVWR of 52,000 lbs. Therefore a 2500 is at 11,200, if weighed on the highway. And max towing , GCWR = 24,500, SAME as a 3500 SRW. Just stay under axles and all is legal. You need to be licensed for that GCWR also, check if those axle weights can be licensed.
04-03-2016, 02:44 PM
I saw a build thread.
Guy in Alaska, took a ram 5500.
Made it a srw with 16 ply tires.
Kept the same gvwr. It was crazy.
Put a srw bed on it too.
Full air ride.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
04-03-2016, 03:08 PM
You'll find conflicting opinions on this. I've been RVing since the mid 70s, pulled and driven most all of the different types, from slide-in campers to class "A's". Currently have a class "C" MH and a 33' 5th wheel. I got out of two 1 ton DRW to get a 3/4 SRW so I could park where I wanted, and go thru the car wash. My rule is don't exceed the GCWR of the truck (truck + trailer) and don't exceed the rear axle rating, in my case 6000#. I don't worry the GVWR unless what I'm pulling, or hauling, is something that doesn't have it's own brakes (read slide-in camper). Too many people trading away perfectly capable trucks to achieve a payload capacity that's not necessary. Two parameters with trailers: GCWR and RAWR!!
04-03-2016, 03:38 PM
Why is it, the only ones disputing gvwr, are the ones that are running over gross in 3/4T??
Gvwr is the most important.
Why adhere to combined, and rear axle... But toss out gvwr?
2016 Sabre 36QBOK
04-03-2016, 04:33 PM
RetiredRVer
X 2!
04-03-2016, 04:39 PM
RetiredRVer
Pretty sure Forest River's published dry weights include full propane tanks.
04-03-2016, 05:33 PM
2016 Sabre 36QBOK
Heck Kenny a lot of people throw out GVWR, GAWR, GCWR and just go by what the website says they can tow. IE F150 can tow 11,500lbs
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
04-03-2016, 06:01 PM
I have noticed..... Just look at the daily 1/2 ton fifth threads..
2016 Sabre 36QBOK
04-03-2016, 06:16 PM
Many folks think that as long as they are under their axle ratings they are "good to go".
In reality if you add the front and rear axle ratings together, you will find the total is more than the Gross Vehicle Weight Rating of the truck. The reason for this is the frame of the truck is the limiting factor in every case (I have found anyway). Yes, it is possible to be under your individual axle ratings, yet still be overloaded.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-03-2016, 06:20 PM
I guess I better plan on reinforcing my Silverado frame.
04-03-2016, 06:37 PM
It was explained to me that the difference in total axle weights and the GVWR is because the Axle Ratings are based off static weight. During towing static weight can increase by 30% or more - like you are going down a hill and put the brakes on the weight from the RV will shift forward on to the pin. The guy that was explaining this was a worked for Ford in the engineering department and now retired and teaching at college engineering classes part time.
