Old 04-02-2016, 12:09 PM   #1
Out of Order
Question regarding 5th wheel pin weight
Does the entire pin weight of a fifth wheel count towards payload in the tow vehicle? I'm assuming so since it seems logical that the pin weight is carried in the bed of the truck. Just looking around for fun I see that my F 250 can tow most popular 5th wheels in terms of max towing and GCVWR but the pin weights are near or at my max payload. BTW, totally happy with our TT but always looking to get educated.
Thanks!
Todt and Connie and Hank the Doodle
2016 Wildcat Maxx 24RG
2016 Ford F250 6.7L Diesel
todtc318 is offline   Reply With Quote
Old 04-02-2016, 12:12 PM   #2
BandJCarm's Avatar
I'm the dummy/novice on this...........but this is the VERY reason that I traded for a Dually in advance of ordering our 5er. I had towing capacity with the 3/4 ton, but it had payload of 2,286 and my pin weight unloaded will be 2,407, and more loaded. I was over the limit before I started. Luckily, I got a great deal on a Dually........but it is Payload that made my decision.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 04-02-2016, 12:44 PM   #3
Otegoans's Avatar
I just went thru all the calculations on my truck to choose a 5th wheel. Yes, the entire pin wt. must be calculated, plus the wt. of the hitch and a percentage of any gear you might add to the coach. there is a sticker on your left door jamb giving you the rear gross axel weight rating. Have the rear axel weighed at a Cat scale or a recycling center. Subtract the actual wt. from the GAWR of the rear axel. The difference is what you can safely carry. I hope this helps , see you on the road!
Otegoans
Ken and Wendy
'15 silverback 29RE
'13 GMC 2500HD
Duramax/Allison
Otegoans is offline   Reply With Quote
Old 04-02-2016, 02:22 PM   #4
bikendan's Avatar
Yes, the entire pin weight factors towards payload.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-02-2016, 02:55 PM   #5
GreenImp's Avatar
Send a message via MSN to GreenImp
Great job doing the math and dispelling the myth that is truck manufacturers marketing. As long as the trailer is properly loaded, TV payload will pretty much always be the limiting factor...at least with SRW trucks...I've never bothered with doing the math on a dually as personally, I would sooner get a smaller trailer.
Side note...Why don't they make a dually where the axle is narrower and all four tires fit in the standard width bed? I realize the space between the wheelhouses would be reduced, but I am pretty sure there would still be plenty of room for a 5th wheel hitch. I would consider this option long before buying one the way they build them now.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 04-02-2016, 04:04 PM   #6
5er_tom's Avatar
Years ago Chevy made a one-off dually that way. Sure reduced bed space, but it would fit in a standard garage. Must not have generated enough interest they did not make them.
Tom & Renée
Durham, NC
2015 Wildcat 295RSX
2012 Ford F-250, 4x4, 6.7 Liter Diesel
5er_tom is offline   Reply With Quote
Old 04-02-2016, 04:06 PM   #7
Tfort's Avatar
Part of the added stability of a dually is the wider stance. Narrowing it to fit in the fenders would bring you back to the same functionality of a SRW 1 ton. The limit difference between the two is the total tire capacity of 4 versus 2 tires.
2000 F250 CC 4x4 7.3L diesel
15 Salem Hemisphere Lite356QB
Tfort is offline   Reply With Quote
Old 04-03-2016, 12:26 PM   #8
CaptnJohn's Avatar
There are many 5ers with pin weights from 1200# - 1700# just as there are some at twice that. Since you own the truck look around and you should be able to find what you want.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 04-03-2016, 12:31 PM   #9
Blog: RVroadtripper.com
hbillsmith's Avatar
As previously said, entire pin weight goes against payload. Another caution has to do with equipment adds. Your 3/4 ton will have a posted payload in the door jam of the truck but that will be reduced for the following: side steps added aftermarket, airbags, total hitch (if it's 2 parts, add both), bed cover, bed liner.
Best way to get the true Payload is to go to a CAT scale and weigh the truck with all your stuff in it. Look at the door jam GVWR (my 2500 is 10,000). Subtract your CAT score from the GVWR and that's your remaining Payload for the trailer.
Now when shopping for the 5er, remember the mfg published pin weight doesn't include the 60# battery and the dual 45# propane tanks.
Some experienced towers compare their payload numbers to whats available for the truck's published rear axle and tires. For instance, my truck's GVWR is 10,000 but the GWR for the front axle plus the rear axle is 11,200. My rig fully loaded is about 1,000 below the Rear rating but almost exactly on the GVWR rating.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-03-2016, 02:38 PM   #10
fljl's Avatar
Adding all the axles is how ALL other highway trucks are calculated on any scales, or road checks. My straight 3 axle farm has a 12,000 + 2 - 20,000 axles = GVWR of 52,000 lbs. Therefore a 2500 is at 11,200, if weighed on the highway. And max towing , GCWR = 24,500, SAME as a 3500 SRW. Just stay under axles and all is legal.You need to be licensed for that GCWR also, check if those axle weights can be licensed.
fljl is offline   Reply With Quote
5th wheel, weight, wheel
