Old 06-12-2015, 10:17 PM   #1
TheDiGs's Avatar
Questions about 5th vs TT towing
My TV is a 2009 Chevy 2500HD, 4WD, Crew Cab, standard bed, 3.73, gas
My towing capability according to the owner's manual:
TRAILERING
Dead Weight Hitch - Max Trailer Wt. 5000 lbs
Dead Weight Hitch - Max Tongue Wt. 500 lbs
Wt Distributing Hitch - Max Trailer Wt. 9800 lbs
Wt Distributing Hitch - Max Tongue Wt. 1470 lbs
Maximum Trailering Capacity 13000 lbs
I am considering a Crusader 5th wheel, 30BH:
Ship weight: 8519
Carrying Capacity: 1365
Hitch Weight: 1143
I am clueless about 5th wheels...can my truck safely tow this? If so, are there hitches that are easily removed to give me my truck bed back when I'm not towing???
Anyone who has switched from a TT to 5er...do you regret losing your bed? We are concerned we will hate losing the truck bed, and we'll have to deal with getting our topper cross country somehow during our move.
Me, Him, a bunch of kids and cats, one loud-mouthed parrot, and one spoiled rotten Shih Poo
2009 Chevy 2500HD 4x4 Crew Cab
2014 33' SOB TT
TheDiGs is offline   Reply With Quote
Old 06-12-2015, 10:32 PM   #2
Assistant TP Supervisor
B and B's Avatar
Hello,
A couple answers to help. We traded from a TT to a Fifth Wheel. I did hate to loose the bed at first. Found the basement storage adequate. As far as getting the bed back when not towing I have a Reese Elite hitch with under bed puck system. The hitch is removed and plugs block the holes.
As far as specs, go to see everything you have here. You need the Cargo Carrying Capacity from the yellow sticker on the drivers door post, also rear axle weight. With out them you are guessing.
You have a 3/4 ton truck and it should tow what you are suggesting. Need the stickers to confirm. The Gas engine might scream a bit on towing hills but will move it fine. Get the stickers CCC and rear axle and we can confirm.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-12-2015, 10:50 PM   #3
TheDiGs's Avatar
Hopefully these are the right stickers...unless you mean the ones on the 5th wheel?
2014 33' SOB TT
Old 06-12-2015, 11:02 PM   #4
TheDiGs's Avatar
Brain is saying I need the info off the trailer...from the Primetime site, CCC is 1551lbs. Doesn't have axle weight (tho I vaguely recall looking at a sticker on the 5th with that info), I'll have to call the dealer for that tomorrow.
2014 33' SOB TT
Old 06-12-2015, 11:15 PM   #5
B and B's Avatar
Looking at your capacity on the Truck you have enough capacity. Just keep the weight down in the truck bed.Your Pin weight would most likely hit 1600- 1700 pounds, As long as the occupants and gear are under 1000 lbs you are within capacity. Bunch of kids and the adults count, I don't think I would worry about the dog, cats or Parrot
The key figure is the 2975 from the Truck. The Trailer weight figures are fine.
http://www.trailerlife.com/wp-conten...Guide-2009.pdf
The tow guide is a good place as well for some information as well.
I tow a 8289 Rockwood loaded close to 9,200 lbs wet. Calculated pin weight is 1700-1800 pounds. I tow this with a F 250 and Diesel. As I mentioned the Gas Engine may have high RPMs at times and get poor miles per gallon. Just the cost of RV travel.
Best of luck with your search, You seem to have al the numbers, maybe a visit to Chev dealer to confirm truck options and tow package capabilities.
Old 06-12-2015, 11:16 PM   #6
Dan'l Boone's Avatar
I have a Ford equivalent of your truck; a 2013 F250 Crew Cab 4x4 6.2l gas w/ 3.73 gears and towing a similar RV with a Shasta Phoenix 28BH. So my set-up seems relatively equal to what you're asking about, although I'm not sure about comparing the engines from different years. I also switched from a bumper pull last year. I've only had a couple of occasions when I regretted having the 5er in the bed; however, I could pull pins and remove it leaving only the rails, which I haven't gotten to the point where I felt I needed to do yet. My truck tows very well, even up hills, but I'm in West Texas. I haven't had any complaints with my set-up or regrets in switching from the TT to the 5er. Very pleased with my decision.
2015 Shasta Phoenix 28BH
2013 F-250 4X4 6.2L Gas
Reese Pro Series 20K# 5th Wheel Hitch
TrailAir Rota-Flex Pin Box
Dan'l Boone is offline   Reply With Quote
Old 06-12-2015, 11:18 PM   #7
trbomax's Avatar
The only thing I can help with is "loseing the box to a 5th wheel hitch". We too had owned horse trailers ,includeing large LQ units.We already had a drop in ball for our goosenecks so it was a simple requirement that the new "5er" be equiped with a Reese Goose Ball coupler.These units are approved by Lippert (actually built by lippert) and feature 5th airborne air ride technology. From experience I can tell you that chucking is non existant and there is no sway from semis or busses. And we still have our full bed use.
trbomax is offline   Reply With Quote
Old 06-12-2015, 11:26 PM   #8
Fulltime family RVer
Who says you lose your truck bed?
I don't necessarily recommend this as I was nervous about my emergency breakaway cable getting yanked by something in a turn.
But, you mentioned a topper/cap- I'm not sure how to tell you to handle that.
Old 06-12-2015, 11:34 PM   #9
Crusadernoob's Avatar
We went from a TT to a Crusader 285RET just about the same weight as what you are talking about. We have an 06 2500HD but a diesel, the truck will handle that fiver just fine, as far as losing bed space, I don't mind, I didn't use it with the TT anyway, the fiver pulls soooooo much better. I think you'll be happy.
2006 2500HD CCSB 2WD 2014 Crusader 285RET
Nights camped in 2013 - not enough!, 2014 37, 2015 40, 2016 39, 2017 38, 2018 29
Crusadernoob is offline   Reply With Quote
Old 06-12-2015, 11:36 PM   #10
B and B's Avatar
Forgot that part, thanks Doug.
I have a 4 KW Generator, waste water hauler, 20 lbs propane for Campfire in the Can, a gas can, soon 10 l of DEF fluid, bags of firewood..
towing
