Old 01-15-2014, 01:16 AM   #1
Packncycle's Avatar
Questions about Weight from Newbie
I have a Forest River popup and Im new at this so trying to figure out how much weight I can carry on the RV based on the GVWR and the GAWR and some of the numbers dont seem to match so I think I have something wrong.
I know that GVWR is Gross vehicle Weight max permissible wt fully loaded and GAWR is Gross Axil weight including cargo safely supported by each axil.
Ok, so my GVWR is 3063 lbs. Dry weight is 2431 lbs and weight of cargo should not exceed 615 lbs. (this is what the stickers say on the side of the trailer) SO that Totals to 3046 lbs But my GVWR says 3063 lbs which is 17lbs difference.. ok thats not bad but it's strange if they go to the trouble of putting the numbers down you'd think that it would equal out. Anyway, that's not my full question:
When I added water (if I carry it) 167 lbs, 2 LP tanks (@ 20lbs each) 40lbs, Battery 41lbs = Total 248 lbs I'll call these "necessities".
So adding the 248 lbs for these "necessities", + Dry weight of the RV 2431 lbs = Total 2,679 lbs
Then if I subtract this amount from the GVWR 3063- 2,679 = 384 lbs (which is the poundage that I have left that I can carry for supplies on the RV?? such as pots, electric cables, other items? Sounds like a lot of poundage but I know it can add up fast having been backpacking a lot. So does this sound right? Ok that was my first real question.
My second question then is the GAWR which is the amount of weight that can go on an Axil which is also stated on a sticker on the trailer. Ok since there is only one axil (2 wheels) .. is it one axil then that holds 2 wheels? If so then here comes the confusing part for me.
My GAWR is 2,750 lbs. If I take that number 2,750 and subtract the RV Dry weight - 2,431 = 310 lbs left for cargo etc, but I still have to subtract the "necessities" that I talked about (water, 2 LP tanks, battery = 248lbs) So 310 lbs - 258 lbs = 52 lbs for all the extra gear. THAT doesnt make sense based on the figures I did on the GVWR? I dont get how these numbers could be so different, when I figure out how much cargo poundage I can have figuring the GVWR and then figuring form the GAWR.
I would like to know how many pounds is safe to carry on the RV after I have the water, LP tanks, battery. Thanks
2014 Rockwood Freedom 2318G
2013 Toyota Highlander
Packncycle is offline   Reply With Quote
Old 01-15-2014, 04:27 AM   #2
fonzie's Avatar
For second question, you have to substract the weight that is carried by the hitch. So if the hitch pin weight is 300 lbs, then that 300 lbs is not carried by the axle fo the trailer but is transfered to the axle of your towing vehicle.
Fonzie
Old 01-15-2014, 08:33 AM   #3
Fulltime family RVer
Since the weight came off of the yellow sticker on the side of the camper, it theoretically already includes the weight of a battery and propane (in your case, likely just a single propane tank). Which means, some of your necessity numbers change.
The very best thing that you can do is take your pop-up to get weighed at a scale. Weigh the tow vehicle (aka truck/suv) + pop-up together and then go park the pop-up and just weigh the tow vehicle.
You have 1 axle. As was previously mentioned- the axle doesn't carry all of the camper's weight. Part of the weight is carried by the tongue/hitch (usually 10%-15% of the overall actual weight). That's why your GVWR can be higher than your axle weight (and, in fact, the GVWR is usually the GAWR + the weight carried by the tongue).
Go get weighed. Anything else is guessing. Weighing is cheap ($10-$15 at a truck stop). And there are a lot of places to get weighed if you aren't near highways.
Old 01-15-2014, 12:32 PM   #4
bikendan's Avatar
yellow sticker weight does NOT include the weight of the battery, since is a dealer-installed item and not installed at the factory.
this is the case for towables, not sure about motorhomes.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-15-2014, 12:49 PM   #5
How does the emergency brake work from the factory to the dealer if there is no battery onboard the trailer?
Old 01-15-2014, 12:52 PM   #6
TURBS's Avatar
Trucking company uses there own battery factory to dealer.
TURBS
golf cart safety instructor
Old 01-15-2014, 01:04 PM   #7
TURBS
TOWTA and I saw a trucker bring a 40' TH into Tom Johnsons in Concord, he walked into the dealer, two guys came out with him, inspected the unit. Driver signed the papers, unhooked and drove off. He sure didn't take any battery with him. Whole process took about an hour as we were talking to him about his 2013 1T DW Duramax being so quiet, etc. Maybe he just donated his battery to TJ.
Old 01-15-2014, 01:09 PM   #8
bikendan's Avatar
TURBS
that's what i was told by my dealer. plus, some trailers, especially popups, are carried on a trailer with other popups.
Old 01-15-2014, 01:28 PM   #9
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
From one 'ol Quality guy to another; Do you suppose they just do a sample test/inspection based upon a known A.Q.L.? And if they do, I think they would be taking a critical item too much for granted. I hope, since the battery is dealer installed item, that they have a portable power supply that they move from unit to unit and test each one.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 01-15-2014, 01:38 PM   #10
Phat Phrog Stunt Crew
mackman1994's Avatar
I drove for a delivery service several years ago and the guys that towed the TT and 5ers had to provide their own batteries.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
newbie, weight
