Old 03-16-2013, 08:51 PM   #11
BDavis's Avatar
Tires are brand new Michelin LTX M/S2.. 275/55/20 size
2016 Sandpiper 365asqb
2013 Rockwood Windjammer 3006W
2014 F250 6.7 PowerStroke 2wd
BDavis is offline   Reply With Quote
Old 03-16-2013, 09:19 PM   #12
Engineer of Crazy Train
ChooChooMan74's Avatar
Are they P or LT? There is a buge difference. My opinion on tires. The P rated will give you a squirmy feel and amplify any movement. I would definitely recommend LT for towing that heavy.
On my little TV, I noticed a big difference between my cheap light stock tires and my oversized better made snow tires.
Also how fast were you towing?
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 03-16-2013, 10:09 PM   #13
Twisty's Avatar
You have a lot of sail area with that long, long trailer.
IMO, way too much for a short wheelbase F150.
I've heard of people getting to test drive new trucks and towing with them.
Try an F250 supercrew with a 8 foot bed.
I would not tow larger than what we have with an F150.
Also, consider the height of the TT. Ours is less than 9 feet high.
And, check the payload on the yellow sticker on the driver door.
I do not have enough truck to tow a 7000 lb 35 foot TT.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 03-16-2013, 10:26 PM   #14
Chuckinca's Avatar
get a 3/4 ton diesel.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
Old 03-17-2013, 07:07 AM   #15
speedcat's Avatar
I went through the same issue a few years ago. Despite any adjustments my 1/2 ton got pushed around, especially on the interstate by the big rigs when towing my 35', 7400lb TT. I switched to a crew cab 3/4 ton and problem solved. Not so much the engine but the stifness of the frame with the extra crossmembers. I did get a big block 8.1 gasser which did not hurt...catch was I realized I could tow more and just traded up to a fiver. I strongly reccomend upgrading your TV. The bottom line is its a matter of safety for you and your family and those on the road around you.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 03-17-2013, 08:56 AM   #16
7000lbs sounds light for that trailer. I highly doubt that is correct for a loaded weight unless that is the trailer axle weight when hooked up to the truck. Getting pushed around a bit is normal and is worse on windy days. Certainly check the hitch, but some push now and then will never go away. You are pulling a giant sail behind you.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-17-2013, 09:04 AM   #17
acadianbob's Avatar
Yes, LT tires do make a difference. Less bounce, less sway.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-20-2013, 07:10 PM   #18
BDavis's Avatar
Well, spent the 20 bucks at Cat Scale today.....GCWR is 15,300. I cam in at 13,800....but didn't have the family, extra gear, etc...so add 500... Just to be safe...14,200lbs. Certainly to close for comfort on the max. As it sat with most of our gear, again minus family and dogs was as follows: gross weight 13820, steer axle 3120, drive axle 3720, trailer axle 6980. Truck itself weighed in at 6060 ( full tank and 2 passengers - no kids, bikes, etc) GVWR for the truck is 7200.
I did add 2 additional washers to the equalizer brand WD hitch...so even though it was much better, still not a joy. Those measurements were with the 2 additional washers for a total of 4.
I reweighed without the WD. Steer axle 2800, drive axle 4160, trailer axle 6860, gross weight 13820.
Our local dealer let us hook up to a 2103 F250 RWD 6.2L gas with max tow, etc....seemed much more stable and didn't push around as much....added some confidence..the F150 was better with the added pressure to the WD, but no 250. So...not sure where to go from here...I think I know what I have to do...weighing it out...and oh, just to note, can't afford the diesel!
Old 07-17-2017, 07:44 AM   #19
I'm in the same prodickument as you. I ended up upgrading my Blue OX Sway Pro bars from 1,000 lbs to 1,500 lb bars. I haven't been back to cat scale since to re-weigh, but hope it gets a little more weight of my rear axle. I pull this weekend with new bars and had next to no sway, but ride was much harsher than with 1,000 bars. I think the 250 might be in my near future after this season.
J007 is offline   Reply With Quote
Old 08-10-2017, 11:16 AM   #20
One good way to decrease sway when towing with a lighter truck is to keep the rear tires inflated a little more than the steer axle tires.
I run the front tires on my Nissan Titan at "Door Sticker Pressure" and add 5# to the rear tires. This gives the rear tires a little more stiffness. Same principle as NASCAR teams use to control vehicle handling, through different tire pressures front to rear, etc. Never run a tire under the door sticker pressure and it's not necessary to go to the max printed on the tire although if your rear axle is a little "heavy" it's not a bad idea.
Lastly, keep your tow vehicle below the max GVW as shown on the door sticker although factory tow packages can increase that amount with factory installed "overload springs". In my case it's 950# Tongue Weight.
If you feel like you are just along for the ride when driving down the highway with wind or big trucks and buses, time to lighten the load (leave some stuff home if necessary) or get a larger truck.
I have it on my dog's authority that an afternoon nap is acceptable.
2004 Nissan Titan
"2004" Male Shih-Tsu Co-Pilot
TitanMike is offline   Reply With Quote
