Old 03-30-2016, 09:18 PM   #1
Quick Question on Weighing TT
I am finally going to weigh my rig with the WDH bars disconnected. Do I throw the bars in the truck bed or not? Also, what does this weight measurement gain me over just performing the my typical truck only weight, and combo weight with WDH hooked up?
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2017: 4 nights camped, 12 booked
Teamfour is offline   Reply With Quote
Old 03-30-2016, 09:25 PM   #2
Wobbles's Avatar
A member here has posted a link that might give you some insight to why, what and how it is done. Hope this helps.
Learn To RV: How to Weigh a Travel Trailer
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 03-30-2016, 09:30 PM   #3
Thanks! I thought I had seen every helpful page like that. I have weighed numerous trailers, just never did the non-WDH step.
Lee and Anne
Old 03-31-2016, 07:51 AM   #4
MtnGuy's Avatar
The non-WDH step will get you a true tongue weight.
Truck and trailer with the WDH not hooked up minus the truck without the trailer will give you the hitch/pin weight.
For kicks and giggles, you can also see what the weight on your axles are without the WDH in place.
Old 03-31-2016, 02:03 PM   #5
Blog: RVroadtripper.com
hbillsmith's Avatar
You need the un-hooked weigh to know if your WDH settings are moving sufficient weight off the rear axle back to the front axle.
Steer Axle WITH WDH minus Steer Axle NO WDH equals Amount weight shifted
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 03-31-2016, 07:47 PM   #6
Too Tall's Avatar
I got my weights without the WDH. I also unhitched and got the GVW of the trailer. Hitched back up and got the split axles. Pain in the As_ because I have trouble latching the ball and I was nervous cause there was an 18 wheeler waiting. But I got her done.
I won't do that again. From now on, I'll get the truck axles separately and trailer split axles.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-31-2016, 11:38 PM   #7
Fulltime family RVer
Next time, park it in a truck spot between weighings and take your time.
Old 03-31-2016, 11:53 PM   #8
Too Tall's Avatar
Yes, I'll do better next time now that I'm a pro, ha. hardly.
USMC 68 -70
Old 03-31-2016, 11:55 PM   #9
Parking in a truck spot is fraught with its own stress. I got into a blind spot and had blocked trucks from getting in at one. One trucker started waving me back- I figured he wasn't leading me astray and I kept going back. Slide in pretty nicely to my spot. I figure he wasn't doing it to be nice (just wanting the silly pilgrim outta his way) but I was thankful none the less.
Old 04-01-2016, 08:56 PM   #10
Too Tall's Avatar
I was so intimidated being out of my element. The scale operator was patient and as helpful as she could be but also running a cash register. She threw me a curve when she said, I'd have to pull my truck completely off the scale after I detached to get the GVW of my TT. Not sure why?
The 18 wheeler saw me pulling out and pulled onto the scale only to find my TT was sitting there with no TV attached. He had to back off the scale. Kind of funny now. I started with hand signals to him, like "just one more weight" and the "little bit left" symbol. I was waiting for the middle finger from him but he was cool.
Now that I know I'm within my GVWR (barely) for the RV. I'm just going to get axle weights from now on. My TV with the Cummins is pretty much "don't worry about the mule, just load the wagon".
USMC 68 -70
