Old 06-21-2016, 02:44 PM   #1
Ram 2500 4x4 Receiver/Shank Question
Just purchased a 2014 Ram 2500 4x4 to get extra towing capacity. The center line of the class V receiver (2-1/2") is 24 inches off the ground. My current trailer has a bottom coupler which is 16" off the ground when level. I'm having great difficulty finding a shank that will go from a class V receiver 24" up, to level the trailer at 16". I have to believe I'm not the only one pulling a trailer with a Ram 2500 (I've seen too many posts here). What are you doing to get your hitch ball low enough? Thanks in advance for your advice/expertise.
Dick & Donna
2014 Ram 2500 4x4
2016 Flagstaff V-Lite 30WRLIKS
RVEagle is offline   Reply With Quote
Old 06-21-2016, 02:55 PM   #2
danny4127's Avatar
REESE has one that goes down 14 inches that worked on mine
danny4127 is offline   Reply With Quote
Old 06-21-2016, 03:02 PM   #3
Kenny kustom's Avatar
My blue ox worked well on my 2500.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 06-21-2016, 03:33 PM   #4
I have a buddy with a 2014/2015 (not sure which) Ram 2500 4x4. It is high in the back for sure. (He tows a 5er, so I don't have an example from his truck.)
I tow a TT with my F250. Of course it doesn't sit as high, however I just upgraded my hitch and shank... so I have been doing a lot of shopping.
One good source is etrailer.com. You can search on shanks and you should find a lot to choose from.
How heavy is your trailer? If you're finding the 2-1/2" shanks have limited variety, try the 2" shanks. Unless you're over a certain weight, the 2" should be fine.
325BH is offline   Reply With Quote
Old 06-21-2016, 03:39 PM   #5
The combo of the high Ram and the bottom coupler is killing you. 8" of drop is big.
Are you sure 24" is the receiver height. I think my buddy's is higher.
Old 06-21-2016, 06:00 PM   #6
325BH - That was my first thought, so I ordered a Reese sleeve to go from 2-1/2" to 2". When it came in, it was clearly marked "Not for Weight Distribution Use". The best 2-1/2" bar I can find is a Equalizer that has a 6" drop. Maybe there is a sleeve that is OK for Weight Distribution.
Dick & Donna
2014 Ram 2500 4x4
Old 06-21-2016, 06:09 PM   #7
I had no idea the sleeves weren't for WD. Interesting.
Old 06-21-2016, 06:25 PM   #8
CaptnJohn's Avatar
09211A3 and FORD is stamped on the sleeve from my F250 nothing else. No indication it is not able to be used with a WDH. Check the manual. I tow a 5er so the sleeve is sitting on a shelf. It came with the truck.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 06-21-2016, 06:56 PM   #9
I use a sleeve and do WD, however my setup is different. I have the TorkLift Superhitch Magnum that has two receivers: a 2-1/2" and a 2". You can use one or both. They have a shank that uses both receivers at the same time. If you went this route, you could buy their really long (big drop) shank, however their hitch and shank is expensive.
Old 06-21-2016, 07:00 PM   #10
I have their shorter (less drop) shank upside down for rise. They have a longer one that would give you more drop.
