Old 05-03-2015, 08:57 PM   #41
Campster's Avatar
I drive around with my exhaust brake on all the time. It doesn't need to be in tow haul mode for it to work but tow haul and the exhaust brake works well together while towing. I believe mine works until it reaches a certain low rpm then it has no effect at all.
Campster is offline   Reply With Quote
Old 05-03-2015, 09:18 PM   #42
fast murray's Avatar
In tow/haul mode with the EB the truck will downshift through the gears as long as you keep your foot off the gas and on the brake. You just have to touch the brake. Without tow/haul and just lifting off the throttle it'll work until it gets down to about 1000 RPM's and then coasts. It'll downshift through the gears in tow/haul without the EB on the same way but without the awesome deceleration provided by the EB. At least that's how it works on my 2012.
2015 Sierra 357TRIP
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 05-03-2015, 09:23 PM   #43
Thanks all. I am sure with all's help i will figure it out.
mike.t is offline   Reply With Quote
Old 05-03-2015, 09:39 PM   #44
Gleaner's Avatar
Nice.
You will enjoy your new ride.
2015 nights camped (54)
Gleaner is offline   Reply With Quote
Old 05-03-2015, 10:06 PM   #45
Originally Posted by Gleaner View Post
Nice.
That you from forest river?
Old 05-04-2015, 04:33 PM   #46
schrederman's Avatar
Wifey calls mine the "Beast"... I've thoroughly enjoyed it, especially towing with it.
J & D in Lovely Weatherford, TX
2016 Jayco White Hawk 28DSBH TT
2014 Ram 2500 Crew Cab 4X4 6.7L Cummins
schrederman is offline   Reply With Quote
Old 05-04-2015, 04:39 PM   #47
schrederman hope i enjoy mine as much as you enjoy yours.
Old 05-04-2015, 06:11 PM   #48
fx2
Haha! Same here. My F150 was "sexy beast" and the Ram is just "beast"
2014 Surveyor SC321BHTS SOLD
2016 Nissan Titan XD SL4x4 Cummins SOLD
2007 Sierra Sport M26FSFB Toy Hauler
2002 Ford F250 7.3l 4x4
fx2 is offline   Reply With Quote
Old 05-05-2015, 12:47 PM   #49
transamz9's Avatar
The exhaust brake has sensors that read a lot of things. The main thing it reads is deceleration. In TH mode it is the most aggressive but it will very it's power by the deceleration factor. If you are going up a steep enough grade that when you let off the pedal the truck loses speed fairly quickly it will not come on. If you are coasting to a light on level ground it will only come on enough to slow you at the set deceleration rate. This rate is different in TH mode and not in TH mode. My truck will apply the exhaust brake and also gear down with the TH mode off but just not as aggressively. When in the Smart Brake mode it senses the speed you want to go by when you let off and touch you break pedal. If you start over a hill and touch the pedal (hard enough to turn the brake lights on) at 40 , then the exhaust brake will do what it needs to do to keep you at 40 or to the best of it's ability. I have seen 150 HP on my exhaust break gauge but that I believe is max it will put out.
I don't believe there is a minimum speed the brake will work but there is a minimum RPM which is around 1000 RPM. My truck with 3.42 gears will work at 30 or so it just depends on the gear the transmission is in when you let off the go pedal.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
Old 05-05-2015, 06:20 PM   #50
Thanks transamz, that's a good explanation and it makes sense. Either way, its awesome and I now that I have it I wouldn't be without it.
2015 Sierra 357TRIP
Old 05-06-2015, 10:36 AM   #51
I just hope I'm still as happy with it in 5 years as I am now. My last work truck went 340K miles with very little trouble. Of course it was maintained, but it only let me down once in all of that time... bad alternator at 225K miles. I do wish you the best of luck and many trouble-free miles with yours.
Old 05-07-2015, 07:40 PM   #52
CJM
That is correct Meep however i was getting around 12 13 towing which is fine but i was getting 12 13 city. I am now getting around 17 city and it only has 125 miles on it so i am hoping for more. And we truck owners want to know what kind of mileage we are getting but for some unknown reason the manufactures don't feel the same unless it is that all powerful "1/2 ton"
On the newer ones you have to be in tow/haul mode as well. I have a 14. Bought it last year, and got rid of my 11 F350. No comparison. . You have made the right choice.
CJM is offline   Reply With Quote
Old 05-07-2015, 08:03 PM   #53
Thanks guys. What a pleasure to drive.
Old 05-07-2015, 08:17 PM   #54
That'll come up as your get her broken in.
rana is offline   Reply With Quote
Old 05-07-2015, 10:17 PM   #55
CJM
I can get 30mpg (Canadian gallons) if I drive 100km/h and no wind. It's ideal condition but it does happen
Old 05-07-2015, 10:18 PM   #56
CJM
I took this at the end of a 200.km drive the other day
Old 05-12-2015, 05:18 AM   #57
I have a RAM 2500 with 3.42 axel. Usually get around 20 mpg w/o tow and I had 16 mpg with a 21ft travel trailer and about 11-12 mpg with a 13k pound 5th wheel. It only has 2300 lb payload capacity however and I'm trading it in for a 3500.
Dennis_TN is offline   Reply With Quote
Old 05-17-2015, 08:27 AM   #58
Thunderbolt75's Avatar
I have an 05 Ram 3500 CTD. I've been towing a 16k fiver since new. Loads of power. Good mileage hitched and empty as well. Your fuel economy will improve when the odometer is north of about 50k miles.
Thunderbolt75 is offline   Reply With Quote
Old 05-18-2015, 08:11 PM   #59
Crusader 816's Avatar
Well I see that we have alot of ram guys here so I have a question. Just bought a 2014 3500 srw ctd. Right now I'm towing a rockwood roo 23ss,with this truck do I still need to use my wdh. Just seems to me it would not need it.
Crusader 816 is offline   Reply With Quote
Old 05-18-2015, 08:13 PM   #60
CJM
WDH will always help. Truck will probably due fine without it, but it can't hurt
