Old 05-07-2016, 09:29 PM   #1
Ram 2500 Diesel Fill Up Issues
Sometimes when I fill up it seems that the tank is full but then when I get down the road the fuel gauge show it is not full. The fuel comes all the way up into the neck and you can not put any more fuel in. I never can check my fuel mileage cause one time it fills up and next it doesn't. What is the secret to fill ups?
2015 Flagstaff 831RBLSS
2015 Ram 2500 6.7 Cummings Crew
2014 Lowe Stinger 175
2013 FJR1300
Hthunder is offline   Reply With Quote
Old 05-07-2016, 09:50 PM   #2
Diesel fuel foams a lot. The only way to gwt it full is once it auto shuts off let it settle for 30 seconds, then manually and slowly continue filling.
donniedu is offline   Reply With Quote
Old 05-07-2016, 10:09 PM   #3
Kenny kustom's Avatar
I had my filler neck replaced on my 3500, a few weeks after buying it.
Hard/slow to fill.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-07-2016, 10:45 PM   #4
doodler's Avatar
Not sure how old/miles on your truck, had a similar problem with mine, about 102000 miles on it, and I got to noticing that sometimes when I fuel up it wouldn't hold but 7 or 8 gallons even after slowly fueling it. It ended up being the float in the fuel tank had rusted to pieces.
doodler is offline   Reply With Quote
Old 05-08-2016, 06:38 AM   #5
I should have mentioned it is a 2015 wth10,000 miles.
2013 FJR1300
Old 05-08-2016, 07:05 AM   #6
RSchleder's Avatar
As a member here as well as the RAM forum, I'd suggest if you don't find what your looking for here, give the Ram forum a shot. Lots of info there on these trucks,
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 05-08-2016, 07:17 AM   #7
fonzie's Avatar
http://www.ramforumz.com/archive/ind.../t-151920.html
Fonzie
Old 05-08-2016, 11:12 AM   #8
Bowhnter's Avatar
My 2015 is hard to get started filling up...I have to get the nozzle just right so it won't keep shutting off. I have not noticed that it hasn't filled up all the way yet though.
Mike and Susan
Cavalier King Charles - Jack (4) and Sadie (3)
2015 Columbus 320 RS
2017 Ram 3500 6.7 Diesel
Bowhnter is offline   Reply With Quote
Old 05-08-2016, 04:52 PM   #9
Thanks for the suggestions and links. Never thought about a Ram forum.
2013 FJR1300
Old 05-09-2016, 09:38 AM   #10
2500 fill up
You didn't mention if you are at a regular gas station or truck stop. If it's at a truck stop in the truck area, as you probably noticed the nozzles are much larger and they pump faster causing a lot of foam. Even the first notch for auto filling are usually to fast also, I found that using a juice bottle cap (like Gatorade) on end, under the trigger of the pump handle works great. The cap keeps the fuel flowing and not shutting off or over flowing, of course you shouldn't leave it unattended.
Det107 is offline   Reply With Quote
Old 05-09-2016, 06:15 PM   #11
I filled up today and I inserted the nozzle as far as I could get it. I held the nozzle and fed the fuel in slowly. It filled all the way up. Maybe I wasn't getting the nozzle passed the second check valve. I have been filling up at service station quick marts. My ford that I had previous to this Ram filled better with the nozzle not stuck in as far.
Thanks for all the suggestions.
2013 FJR1300
Old 05-09-2016, 07:06 PM   #12
Wa11y757's Avatar
Maybe dodge has a "harpoon" mod like the ford psd.
Wa11y757 is offline   Reply With Quote
500, diesel
