Old 05-07-2016, 03:44 PM   #1
Kenny kustom's Avatar
Ram 3500 lowering
I went from an 08 F350 to a 15 ram 3500. Both 4wd.
The ram sits quite a bit higher, so I went about lowering it today.
Here you can see the spacer blocks under the springs.
Name:	ImageUploadedByForest River Forums1462653450.877678.jpg
I ordered a new set of u bolts ( never re use them)
Disassembled the spring pack.
Name:	ImageUploadedByForest River Forums1462653517.682151.jpg
Moved the spacers to the top, in order to keep the same u bolt length.
Name:	ImageUploadedByForest River Forums1462653574.290299.jpg
In the end, I used two, of the spacers.
Name:	ImageUploadedByForest River Forums1462653618.578865.jpg
Name:	ImageUploadedByForest River Forums1462653645.351661.jpg
Even with only 11km on it, the nuts still needed some persuasion.
My favourite tool. I hate the torch.
Name:	ImageUploadedByForest River Forums1462653751.281235.jpg
I ended up with about 1.5" of drop.
I was also able to lower the hitch head, 1.5" as well.
I pick the trailer up from storage on Tuesday. We'll see if it's enough to level it out.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 05-07-2016, 11:47 PM   #2
Fulltime family RVer
Oh man- how nice! I hate how tall my 4x4 is.
ependydad is online now   Reply With Quote
Old 06-14-2016, 03:53 PM   #3
DAISY BOYKIN's Avatar
Exact reason------------
Exact reason I bought a two wheel drive. Two wheel drive sits quite a bit lower than a four wheel drive. Even with the two wheel drive I still had to put the fifth wheel hitch in the lowest position.
When my fifth wheel ran 1 1/2" high at the nose, the two rear wheels on the Rockwood ran 12-20 hotter than the front wheels because they were carrying more weight.
I know in the north country where you have snow, you need four wheel drive trucks in the winter.
As you can see a pretty good match.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-16-2016, 10:50 PM   #4
Left Coast
Also lowered my old 99 2500 4x4 Dodge....had changed hitches, and new one was 5" taller....so, raised pin and lowered truck....
