Old 04-22-2015, 03:46 PM   #1
avolnek's Avatar
Ram 6.4 Hemi owners service bulletin
I caught word from a buddy of mine with a 6.4 hemi that there is a recall/tech service bulletin comin down the pipe for a window of 6.4 hemi's.
Apparently there is a bulletin out for the 2014 model's
Model-Code
2500- DJ
3500-D2
3500CC-DD
4500/5500- DP
applying to vehicles built between June 16 2014 - October 7 2014.
The issue was the wrong wrist pins were installed in the engine causing a cold start knocking/ticking.
Solution appears to be a new engine...
My buddy's truck has gone under the knife already and a new engine is under way. There is also one other case for sure that i know of.
My truck is scheduled to go in on the 30th to be looked at for this noise. I had actually scheduled prior to hearing all this information and assumed maybe a cracked manifold or broken bolt...
lets hope for the best i suppose but RAM felt it necessary to issue me a case # prior to even getting my truck into the shop...
I will do my best to keep everything current...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 04-23-2015, 04:45 AM   #2
searay245se's Avatar
At least its a good thing that Ram is owning up to the problem and fixing it instead of just telling the owners that it is normal for them to sound like that....I guess I don't have to worry,mine came off the line just last month but I will be following this to see what happens.
Jeff & Debbie
2015 Tracer Air 255
2015 Ram Laramie Power Wagon 2500
searay245se is offline   Reply With Quote
Old 04-23-2015, 11:31 AM   #3
Jopar's Avatar
I have been a dodge technician for 22 years this service bulletin is only within a time window. If your truck was built on or after June 16th and before October 7th 2014. Yes the fix is a complete engine swap. Some guy at the engine plant must have been smoking that funny stuff when building the engines. 😂
2012 dodge durango hemi awd with tow package.
2015 Rockwood roo 23ss
Jopar is offline   Reply With Quote
Old 04-23-2015, 12:05 PM   #4
thebrakeman's Avatar
Originally Posted by avolnek View Post
...for a window of 6.4 hemi's...
At first read, I thought there was a window-glass problem, that only affected trucks with 6.4L Hemi engines!
They always try to fool-proof (aka "poke-yoke") these things to make it impossible to screw up. But that's not always possible/practical.
Good luck.
thebrakeman is offline   Reply With Quote
Old 04-23-2015, 12:38 PM   #5
avolnek's Avatar
Your dates are what I seen as well.
It appears that Ram is doing what they need to do to correct the issue, which is all that can be asked...
There will always be issues, how they are fixed is what makes a builder who they are...
Old 04-23-2015, 12:51 PM   #6
how do we determine built date?
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 04-23-2015, 12:59 PM   #7
avolnek's Avatar
It is written right on the door sticker with the vin number. (drivers side door.)
Old 04-23-2015, 01:00 PM   #8
Left Coast
Door sticker
Old 04-23-2015, 01:10 PM   #9
I suppose i can wait long enough to go home and check the truck. Thanks for the info
Old 04-23-2015, 01:48 PM   #10
Jopar's Avatar
Avolnek I would be careful posting a VIN# people can find out a lot with that VIN#. Just saying
