Old 01-16-2016, 12:06 PM   #11
Homebrew's Avatar
I do a lot of highway driving and found keeping the exhaust brake on help when people pull out in front of you with signaling.
Also the dealer informed me that people have gone 80k mile before brake change using the exhaust brake.
Sounded logical to me, is there a negative side to using the exhaust brake?
Tow/haul does not allow to shift in to higher gear as quick. I don't see the need to use this with no load.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-16-2016, 12:21 PM   #12
Campground host Mo. State
Photogirl's Avatar
On our 2008 Ram 2500 I have Installed a H&S Mini Max tuner, in options menu is a diesel brake always on feature . but it can be turned off if desired. with the dash switch.
Frank & Kathy & Daisy 2.0 Yorkie (Pack leader)
2008 Ram 6.7 Diesel, 4.10 diff., EGR valve delete, MBRP straight exhaust, Mini Max race tuner, K&N
2016 Crusader 321 RES Ham call W0FCG
Days camped in 2015- 111 in 2016-75 in2017-61
Photogirl is offline   Reply With Quote
Old 01-16-2016, 12:33 PM   #13
mike.t's Avatar
Originally Posted by Kenny kustom View Post
Exhaust brake helps warm up time.
It was -36 here this morning.
Even when not towing I use exhaust brake and tow haul mode.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Not quite sure how. Fast idle sensors note the air temp and adjust accordingly to insure how fast it will take to get to optimal working temps.
Mind if i ask where you were when it was minus 36
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 01-16-2016, 12:35 PM   #14
gectisme's Avatar
I just turn on the Cruise Control and it goes into a higher RPM for warm up. What does enabling the Exhaust brake do to warm up faster if you are not braking?
Ah, missed the part of the higher idle until I just re-read it. Turning on the Cruise Control does the same thing.
2016 Windjammer 3006WK
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper). Equalizer E4 1.4k/14k WD Hitch. TST 507 TPMS. Furrion FOS48TA Observation Camera. Garmin RV-760 GPS. Honda 2000i Genny, PI EMS-PT30C.
MISSION COMPLETED!
gectisme is online now   Reply With Quote
Old 01-16-2016, 12:47 PM   #15
The negative to using the exhaust break for warm ups is that it may foul up the exhaust portion of the turbocharger resulting in a P2262 error code. It may also foul up all that anti pollution equipment. On our 2007 6.7 3500, I used the exhaust break for faster warmups when the temperature was near the freezing mark and got an error reading 80% full on the catalytic converter system. Had to waste fuel for about an hour of highway driving to clean it out. Since then I too did the exhaust delete and added the Mini Max Tuner however in our low teen temperatures I did get the P2262 error. This morning's Temp in mid Sask. was -31 .
grandpacsf is offline   Reply With Quote
Old 01-16-2016, 01:03 PM   #16
Homebrew's Avatar
Does the 2007 use DEF ?
2014 Ram 3500 DRW
Old 01-16-2016, 01:17 PM   #17
This 2007 6.7 is pre DEF.
Old 01-16-2016, 03:41 PM   #18
Kenny kustom's Avatar
Straight from the CUMMINS supplement manual.
Name:	ImageUploadedByForest River Forums1452980463.156133.jpg
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 01-16-2016, 03:43 PM   #19
Using the exhaust brake is different than just a high idle.
With the mod plug, it will turn on brake and high idle when remote started.
2016 Sabre 36QBOK
Old 01-16-2016, 04:05 PM   #20
mike.t's Avatar
Guess i missed where this was going. My manual say's basically the same thing. It's intended to get warm air for the cab faster. Interesting. My manual also say's"the exhaust brake feature will only function when the driver toggles it on by pushing the exhaust brake button until the "Exhaust Brake Indicator" is illuminated.
2015 Salem 27RKSS
55' Chevy Bel-Air
brakes, modifications
