Old 01-15-2016, 09:01 AM   #1
Kenny kustom's Avatar
Ram exhaust brake mod
I had a few people pm me about this mod.
Basically, when a trailer is plugged into the truck, the exhaust brake is automatically turned on, upon start.
Running the exhaust brake speeds up the warm up time quite a bit.
What i did, was trick the truck into thinking a trailer is attached.
Simply place a 10w 12ohm resistor between the trailer brake wire and ground.
This simulates the trailer brakes.
IMPORTANT ! YOU MUST TURN YOUR BRAKE CONTROLLER DOWN TO 0.
You dont actually want any current flowing through the resistor.
This only works with the factory brake controller.
Upon remote start, the engine brake will come on, and it will high idle.
Sounds great with an intake.
Old 01-16-2016, 05:59 AM   #2
Homebrew's Avatar
What year is your truck, my 2014 requires I turn on the brake even when the trailer is hooked up.
I guess I should look into the program to see if I can change it.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is online now   Reply With Quote
Old 01-16-2016, 06:02 AM   #3
This was done on a 2014 2500.
It does not work on my 15, 3500 because I don't have the factory brake controller.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-16-2016, 06:19 AM   #4
Homebrew's Avatar
I have the brake control built in on my 3500.
Like I said I'll look into reprogramming if it allows me. Great idea ,thanks for sharing your mod.
2014 Ram 3500 DRW
Old 01-16-2016, 07:35 AM   #5
It shouldn't need any programming.
Even with your 7 pin plugged in, you have to press the button after start?
2016 Sabre 36QBOK
Old 01-16-2016, 07:56 AM   #6
Homebrew's Avatar
Ok- I was hoping to get to turn on without pressing the button inside the truck.
2014 Ram 3500 DRW
Old 01-16-2016, 08:00 AM   #7
Homebrew's Avatar
2016 Sabre 36QBOK
Yes - I have to press the button every time I shut the truck down with the trailer plugged in.
2014 Ram 3500 DRW
Old 01-16-2016, 09:38 AM   #8
Ask the dealer about that.
Standard operating is that it should auto activate when a trailer is plugged in.
2016 Sabre 36QBOK
Old 01-16-2016, 11:40 AM   #9
mike.t's Avatar
1st. Doesn't a light come on in the dash when the exhaust brake is activated?
2nd Why would you want it on when not towing?
3rd The exhaust brake works a lot better when in T/H mode.
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 01-16-2016, 11:45 AM   #10
Exhaust brake helps warm up time.
It was -36 here this morning.
Even when not towing I use exhaust brake and tow haul mode.
2016 Sabre 36QBOK
brakes, modifications
