06-17-2019, 08:54 AM
Ram light and heavy electric trailer brakes
I just bought a new '18 Ram 2500 with the factory Integrated Trailer Brake Controller. I am trying to set up the trailer brake gain on my travel trailer and I am unable to select "heavy electric" through the steering wheel switches.
I pull up the towing menu on the dash display and it defaults to light electric with the little cargo trailer symbol. I can adjust gain but even at 10 I don't think the braking is aggressive enough with manual application of the brakes. I am following the owners manual instructions but I can't get heavy electric to display on the menu.
I have the Uconnect 3.0 with the 5 inch screen if that's important.
2018 Ram 2500 Tradesman, CTD/CC/SB/4X4/Equalizer WDH
2019 Forest River Surveyor Legend 19BHLE
06-17-2019, 09:49 AM
i have been able to set mine to heavy electric.
there are four possible settings
light electric
heavy electric
light hydraulic
heavy hydraulic
does anybody know what the differences between these four setting are and when each would be appropriate? for example, what is the transition point between selecting light electric versus heavy electric?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
06-17-2019, 10:21 AM
light electric
heavy electric
light hydraulic
heavy hydraulic
I think 10k, but really it depends on your specific trailer and if you need more braking or not. Our TT is an ultra light but I like having the controller on heavy and on a low brake setting. On light I have to have it on a high setting.
2007 Rockwood 2701SS
1953 GMC 9314
1982 GoldWing Interstate
06-17-2019, 01:12 PM
Failure is my business
On mine you need to go into the settings on the radio to set which trailer type you want. Both on the 8.4 and 5 inch screen versions.
The heavy setting seems to apply voltage a bit more aggressively than the light. Now that I've got an exhaust brake it really makes no difference.
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 24 Cedar Creek 40CBK
06-17-2019, 01:39 PM
Try this youtube
Hope this helps Tim
06-17-2019, 01:47 PM
Thanks, it's a learning curve for the technology challenged to figure out the settings.
06-18-2019, 12:30 PM
We have a 36’ Cardinal 5th wheel, I have mine set on heavy electric.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
06-18-2019, 03:05 PM
Thanks, my TT is pretty light but I wanted to see how to pull up "heavy electric" on the menu as part of my trailer braking testing process.
06-21-2019, 11:19 AM
I'm towing right around 8K and I have mine set on heavy electric 5.5
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30X
06-21-2019, 09:23 PM
My TT is 6k loaded and I have mine set at light electric at 5.
06-29-2019, 05:34 PM
Set mine to heavy ... will give it a try
Frank & Cindy--- (SOB) 5th Wheel ---2019 Ram 3500 Cummins 6.7 SRW 4x4 8' bed--- Payload 4394------Remi & Sage camping pups---TST 507 TPMS ... B&W Patriot 18K---3.73 axle ... Predator 3500---2019 48 days ---2020 28 days Camping
06-29-2019, 06:16 PM
When I had my 9k trailer I used heavy hydraulic and it worked great. Hydraulic seems to send power to the brakes a little faster. Nobody nowhere has ever come up with a data backed explanation of the difference between the four settings...just a bunch of bull spread all over the internet. Try all four and use whichever feels best to you. Every trailer is going to be different.
BIRDS AREN’T REAL
07-01-2019, 09:30 AM
According to the manual, light electric for under 10K lbs, heavy electric for anything over.
That said, I was at 9 gain on heavy electric on my 5K lbs TT and on the same settings with my fifth wheel...
Truth be told, I don't really use the brakes much, the engine brake does an excellent job. Even when pulling into rest areas, I don't touch the brake pedal until it's time for a complete stop
2020 Coachmen Chaparral 360IBL
2018 Ram 3500 SRW
