Originally Posted by sierramister
I think we're still not at the bottom of the this door-sticker-vs-150-pound-plus-fuel discussion.
VIN lookup from RAM (both consumer site and dealer site) say *my specific RAM 2500* has a payload of 2400. Door sticker says 2200.
Same deal on my Rebel... ~950 on the door and ~1100 from VIN lookup.
From the Ram Owners manual (2017):
"Gross Vehicle Weight Rating (GVWR)
The GVWR is the total permissible weight of your vehicle
including driver, passengers, vehicle, options and cargo.
The label also specifies maximum capacities of front and
rear axle systems (GAWR). Total load must be limited so
GVWR and front and rear GAWR are not exceeded.
Payload
The payload of a vehicle is defined as the allowable load
weight a truck can carry, including the weight of the driver,
all passengers,
options and cargo.
Gross Axle Weight Rating (GAWR)
The GAWR is the maximum permissible load on the front
and rear axles. The load must be distributed in the cargo
area so that the GAWR of each axle is not exceeded.
Each axle GAWR is determined by the components in the
system with the lowest load carrying capacity (axle,
springs, tires or wheels). Heavier axles or suspension
components sometimes specified by purchasers for increased
durability does not necessarily increase the vehicle’s
GVWR."
Regarding Ram Tire Loading, the pressures are spec'd to the GAWRs not GVWR. That explains the 12k+ load carrying on a 10K GVWR 2500.
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
