Old 07-19-2013, 11:17 PM   #141
Oklahoma Proud
MillerTime's Avatar
Phone apps don't show or have the face thingys on them. That's a browser thing, so im not real sure what a rolfback or whatever, really is. I know this though
Old 07-20-2013, 12:25 PM   #142
dcheatwood's Avatar
Let me start with a big ;^)
This mileage was after 500 miles towing. Reset at start of trip. This is avg mpg, not current. Most of trip was I-20 at 62 mph. I, too, can go to next item on dash for current mpg and peg out the graph at 60+ mpg. I've determined that's why mountainous terrain gives better mpg. 4 mpg up hill and 60 + mpg down hill avgs higher than flat country at 10 mpg.
2018 Forester 3011 DS
Old 07-20-2013, 01:43 PM   #143
Just finished 3250 miles from Montana to Northern CA, up the coast to Portland, up the Columbia Gorge through the panhandle of ID and back to MT. We crossed the divide several time, and had a lot of windy mountain driving as well as high altitude driving. We also had a lot of desert driving on interstate at 70-75 MPH. Keep in mind our 5th dry is over 14k lbs. We had a full load with water and food for 5. I would guess about 16k lbs. We got 10.5 mpg for the entire trip.
I used all the power our Duramax had to offer on some of those divide crossings.
2012 GMC 3500 Duramax Crew Cab, SuperGlide 20k
2014 Cedar Creek 36B4, LP Onan, Level-Up, Trail-Air pin, electric fridge
Campwell is offline   Reply With Quote
Old 07-20-2013, 08:35 PM   #144
zs325RES's Avatar
I'll throw in -
Average 8.5mpg pulling in Michigan - two trips.
between 60-65mph, running in overdrive on the flats @ 2000rpm with no problem. Trans never got over 180deg, engine 200deg - Air conditioning running the whole time.
Love my Silverado!
2020 SOB - Jayco North Point 387RDFS
2013 Crusader 325RES Touring Edition - SOLD
TV: 2018 GMC Sierra Denali HD CC SRW L5P Duramax
Curt Q20
zs325RES is offline   Reply With Quote
Old 07-20-2013, 09:10 PM   #145
Originally Posted by zs325RES View Post
I'll throw in -
Love my Silverado!
Come on down to Arizona, we can increase those transmission and engine numbers considerably.
Jack
jaherbst is offline   Reply With Quote
Old 07-22-2013, 07:01 AM   #146
Guest
'12 Tundra, 5.7 with 4.30 gears. Both longer trips this year were on SR37 (Indiana) and other state highways with lots of towns, stop and go, and hills. Our 261BHXL weighs around 5500# with water and gear. Calculating by hand I came up with 11 mpg, regardless of having the AC on or not. I honestly consider that pretty decent. And I drive like an old man.
John4th is offline   Reply With Quote
Old 07-22-2013, 12:26 PM   #147
dcheatwood's Avatar
I'll take that any day.
Old 07-22-2013, 03:52 PM   #148
Guest
I'm surprised you get 10mpg pulling that large of a trailer. I think I have a shot at 12mpg if I can get some interstate running. Taking off constantly from stop lights are mpg killers when towing. I would get 12-13mpg when towing our 4100# hybrid last year.
Old 07-22-2013, 03:55 PM   #149
dcheatwood's Avatar
I see a noticeable difference between 60-70 mph. I'm usually in the 60 range to get the 10 mpgs.
Old 07-23-2013, 05:33 AM   #150
rambilt's Avatar
Dcheatwood, how much air (PSI) you put in your Air Lift 5000? Mine I vary from 15psi and 20PSI. It seems to not matter in the way the truck rides...
rambilt is offline   Reply With Quote
Old 07-23-2013, 09:07 AM   #151
dcheatwood's Avatar
I run 5 not towing and 45 or 55 when towing. It helps most with sag and bottoming out on bucking roadways like we have here in LA. Really noticeable but you have to pump it up. I have wireless remote so I can adjust on the fly. Found 55# feels best in most cases towing.
Old 07-23-2013, 09:11 AM   #152
Newbie.
monte0999's Avatar
Agreed. I run the same. I believe the book says 1 psi for every 50 lb of added pin weight.
2013 344 QBOK
2011 F250 4x4 Supercrew Diesel
monte0999 is offline   Reply With Quote
Old 07-23-2013, 09:18 AM   #153
Camper Less Camping
Cajun Po-Boy's Avatar
Yes, 50 psi in bags supports a 2500lb load, 100 psi supports 5000lb load etc...
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-23-2013, 09:24 AM   #154
jevanb's Avatar
65psi for me, tried multiple pressures and it works the best.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-23-2013, 09:40 AM   #155
WestCoastRV'er's Avatar
21 L/100KM or 11 MPG
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 07-23-2013, 11:56 AM   #156
dcheatwood's Avatar
At that ratio I'd be running 25-30 psi with 1300-1400 pin weight. Seems less bouncy at 55 psi. I like the idea of taking some of the pounding off of the springs too.
Old 07-23-2013, 04:13 PM   #157
Certified Curmudgeon
19.5L/100km since I'm in Canada. That's "aboot" 12.1 mpg so far over 6000 miles.
It's still a lot of fuel at 1.375 CD/liter.
Mike Dropped
Old 07-23-2013, 05:55 PM   #158
rambilt's Avatar
dcheatwood, monte0999, Ragin Cajun and jevanv,
thanks guys for the replies.. Didn't mean to hijack the thread.... I'll pump mine to 55psi next time. Thanks again guys!
Old 07-23-2013, 06:25 PM   #159
dcheatwood's Avatar
Also sorry. forgot this was mpg topic.
Old 07-23-2013, 07:02 PM   #160
Gizmo0706's Avatar
We got 8.7-8.9 out of our new "bus" pulling through the mountains our last trip. I think we might be able to break into the 9s on flat ground, how exciting!
Gizmo0706 is offline   Reply With Quote
