Old 07-23-2013, 10:07 AM   #151
dcheatwood's Avatar
Originally Posted by rambilt View Post
Dcheatwood, how much air (PSI) you put in your Air Lift 5000? Mine I vary from 15psi and 20PSI. It seems to not matter in the way the truck rides...
I run 5 not towing and 45 or 55 when towing. It helps most with sag and bottoming out on bucking roadways like we have here in LA. Really noticeable but you have to pump it up. I have wireless remote so I can adjust on the fly. Found 55# feels best in most cases towing.
2018 Forester 3011 DS
Old 07-23-2013, 10:11 AM   #152
Newbie.
monte0999's Avatar
Agreed. I run the same. I believe the book says 1 psi for every 50 lb of added pin weight.
2013 344 QBOK
2011 F250 4x4 Supercrew Diesel
monte0999 is offline   Reply With Quote
Old 07-23-2013, 10:18 AM   #153
Camper Less Camping
Cajun Po-Boy's Avatar
Yes, 50 psi in bags supports a 2500lb load, 100 psi supports 5000lb load etc...
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 07-23-2013, 10:24 AM   #154
jevanb's Avatar
65psi for me, tried multiple pressures and it works the best.
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 07-23-2013, 10:40 AM   #155
WestCoastRV'er's Avatar
21 L/100KM or 11 MPG
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 07-23-2013, 12:56 PM   #156
dcheatwood's Avatar
At that ratio I'd be running 25-30 psi with 1300-1400 pin weight. Seems less bouncy at 55 psi. I like the idea of taking some of the pounding off of the springs too.
Old 07-23-2013, 05:13 PM   #157
Duckogram's Avatar
19.5L/100km since I'm in Canada. That's "aboot" 12.1 mpg so far over 6000 miles.
It's still a lot of fuel at 1.375 CD/liter.
ILB
Old 07-23-2013, 06:55 PM   #158
rambilt's Avatar
dcheatwood, monte0999, Ragin Cajun and jevanv,
thanks guys for the replies.. Didn't mean to hijack the thread.... I'll pump mine to 55psi next time. Thanks again guys!
rambilt is offline   Reply With Quote
Old 07-23-2013, 07:25 PM   #159
dcheatwood's Avatar
Also sorry. forgot this was mpg topic.
Old 07-23-2013, 08:02 PM   #160
Gizmo0706's Avatar
We got 8.7-8.9 out of our new "bus" pulling through the mountains our last trip. I think we might be able to break into the 9s on flat ground, how exciting!
Gizmo0706 is offline   Reply With Quote
