Old 03-07-2016, 06:53 AM   #1
Rear cargo
My trailer comes with a factory dry tongue weight of 12.5%. However, a lot of the storage, including the under bunk storage and rear cargo rack (factory installed) is behind the rear axel. Are there any issues with loading heavy items in these areas, and the lower tongue weight as a result, as long as I maintain at least 10% tongue weight which appears to be the minimum recommended?
Greywolf26dbh is offline   Reply With Quote
Old 03-07-2016, 07:06 AM   #2
acadianbob's Avatar
Certainly, at some point, too much weight back there can become an issue. It would likely surface as a tendency for the trailer to sway. You may have to "experiment" a bit to see how it goes. One thing you can do is make sure that your tongue height is level to lower than the rear bumper.
It's interesting how trailers are designed. Our current trailer puts any additional weight in front of the trailer axles. So, we get a lot of tongue weight out of that.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-07-2016, 07:18 AM   #3
Yes, they say 200 lbs max on cargo rack but that will result in close to 100lbs off tongue weight. Also the grey water tanks are behind the axel which could be even more off tongue weight on ride home. I did buy a sherline tongue scale so I can be sure to maintain the 10%
Old 03-07-2016, 08:59 AM   #4
CWSWine's Avatar
The Toy Haulers folks are the best on to talk to about loading heavy in the rear. I don't own one but have read many post that their 1,000 lbs toy only reduces the pin/tongue weights less than 200 lbs. Yes, you should always watch how you load your RV and the affects it has on towing.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 03-09-2016, 01:51 PM   #5
thebrakeman's Avatar
Keep in mind, battery and propane has a lot of weight. Also, where is the fridge and pantry? In the end, you just need to load it up and check it. If it's lighter than 10%, adjust.
thebrakeman is offline   Reply With Quote
