Old 03-03-2016, 10:16 AM   #21
tjm
Originally Posted by steelpony5555 View Post
too many people forget they have a truck ...you put some weight in the bed it'll sag a little...like I said a little...most trucks are built with the rearended a lil high anyways.....
Trucks are built with a rake to level the truck when loaded. However if you put enough load onto the truck that the sag is past level, the WDH will bring it back up to where it should be.
tjm is offline   Reply With Quote
Old 03-03-2016, 10:32 AM   #22
TURBS's Avatar
Originally Posted by WolfWhistle View Post
HTs... 4 for sale on 17" Ram chrome wheels (8 bolt) with over 50% tread remaining (shameful sales plug). Although traction is excellent and they are super quiet on the highway, off-road they are not so good.
WW
Yeah the at's have much better traction!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 03-04-2016, 04:10 PM   #23
thebrakeman's Avatar
I know most guys want to make their trucks level with the WDH. But it's a truck, when towing weight it is not a bad think for the rear to sag just a bit. It helps with everything from sway to pushing you thru turns.
Exactly. You want the front to be back to stock height. But the rear will still be lower than stock. If the rear is back to stock height, your front could be seriously overloaded.
thebrakeman is offline   Reply With Quote
Old 03-04-2016, 07:12 PM   #24
rracer5's Avatar
And rear severely UNDERWEIGHT!
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
