Old 05-18-2012, 10:43 AM   #1
Tee
Tee's Avatar
Rear RV Hitch
Anybody know of other brands of hitches for the rear of trailers. I found a couple made by Curt and one made by Hidden Hitch. Seems there would be more hitch companies building these?
Tee is offline   Reply With Quote
Old 05-18-2012, 10:53 AM   #2
TURBS's Avatar
Not sure what u want to mount on the hitch but warranty on frame is voided when anything is attached to frame or bumper.
You didn't say make model or year either.
Old 05-18-2012, 11:07 AM   #3
FreedomTracker's Avatar
Agree with turbo... not recommended. Suggest search many posts on this subj...
If you still want a receiver, suggest find a knowledgable welding shop with lots of experience building custom hitches. Also suggest keep wt to a min.
Good luck.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 05-18-2012, 11:09 AM   #4
Tee
Tee's Avatar
Oh, I have a 2013 Rockwood 8289WS.
My last trailer had one of these from the factory.
I have read about the warranty deal. And from what I can tell, Lippert will not warranty it anyway? They appear to be quite creative in comming up with reasons it wasn't there fault the frame failed.
Old 05-18-2012, 12:18 PM   #5
TURBS's Avatar
my sabre has a factory installed bike rack/cooler hauler rated for 450lbs .
im a member of the failed bike rack hitch years ago . never again .
I would hate to recomend somthing for you .
Old 05-18-2012, 05:08 PM   #6
Brigitte
boubou's Avatar
Is your Sabre factory installed bike rack/ cooler hauler safe for bikes?
Just not sure by what you meant when you said you had a bike rack hitch fail. Not the current one right?
Asking because my Shasta Revere also has a bike rack/ cooler hauler whatever tray on the back of it.
2013 Jayco Eagle HT 23.5
2010 Ram 1500 HEMI with integrated brake controller, tow mirrors and Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi but we keep them 50-55 psi
Superglide 2700
Timbrens
boubou is offline   Reply With Quote
Old 05-18-2012, 05:50 PM   #7
IMO, none of them are safe to carry bikes whether factory installed or aftermarket. The shock loads generated by the roads which is magnified by the bikes will eventually break either the rack or the frame where it mounts. Best thing to do with bikes is make a stand up rack to set inside the trailer.
Old 05-18-2012, 07:35 PM   #8
Brigitte
boubou's Avatar
Even a factory set up like this one?
ID:	14070   Click image for larger version
ID:	14071   Click image for larger version
Superglide 2700
Timbrens
Old 05-18-2012, 08:03 PM   #9
That's one of the better ones I've seen, but I still would not put bikes on it unless they were secured to where they could not shake or vibrate. The shaking/vibration is the villain on any steel frame. Voice of experience.
Old 05-18-2012, 08:06 PM   #10
Brigitte
boubou's Avatar
There is a vertical component to it for bikes. I should have put it up for show but it's dark outside now. Regardless, we don't plan on taking bikes, we are busy with the dogs. I posted this just for sake of argument. Might puta box on it for gear. We also cannot have bike in our trailer, slide is too big.
Superglide 2700
Timbrens
led pad
