Old 06-30-2016, 11:31 PM   #21
Originally Posted by Fushux View Post
I have a 63 gallon RDS tank that ties in to the filler neck of the main tank. Works wonders. I'll drive from Oregon to so Cal without filling up but it's about $250 each time I fuel up. The only thing I don't like is the cap is a little taller than my bed rails which would prevent me from putting a cover. Here are some pics.
Sent from my SM-G935V using Tapatalk
I have this same tank. Had it my 2010 Dodge and now my 2015 Chev. Using a Access Original model roll up cover it all fits underneath. I just use the manual shut off valve and their adapter kit. Took about 45 minutes to install in my Chev. I'll never travel without it.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 07-01-2016, 12:39 PM   #22
Northern Tool w/valve to fuel filler
I installed a RDS 35 gal (holds 37) purchased from Northern Tool, it is a low design as I have a Hard bed cover. Very happy with the new combined 780 mi. range in my 2500 diesel. The filler unit was a bit of a challenge for this 76 yr. old laying on the cement but came out well. I have a valve and start with it closed and open when orig. tank gets low
Burk
275RLS Wildcat
Burk is offline   Reply With Quote
tank
