Old 03-09-2016, 11:34 AM   #1
phillips's Avatar
Reese Dual Cam
My dealer is installing a Reese Dual Cam WDH and i was told that this has sway control built in? I figured i would ask here to make sure the info im being told is correct? thanks!
phillips is offline   Reply With Quote
Old 03-09-2016, 11:51 AM   #2
Yes it does. I don't own one so can't speak of how good. However, I've only read good reviews and a lot of them. Do a search and you'll get more than you care to read about all WDHs.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
Scotty is offline   Reply With Quote
Old 03-09-2016, 02:06 PM   #3
I LOVE my Reese Dual Cam; in fact I posted a couple of reviews on it earlier today:
http://www.forestriverforums.com/for...ml#post1124946
http://www.forestriverforums.com/for...ml#post1124970
...and my review on e-trailer is the first one:
https://www.etrailer.com/Weight-Dist...e/RP26002.html
If you have any specific questions or want some pictures, let me know...
2006 Ford F-350
2014 Wildwood 28DBUD
Pick_PSD is offline   Reply With Quote
Old 03-09-2016, 02:18 PM   #4
Dodge Guy's Avatar
As long as the dealer installs it properly you will be very happy with how well it performs! however most dealers do not know how to set them up properly!
Good luck!
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 03-09-2016, 02:20 PM   #5
^^Good point; I did mine myself. The instructions were good and e-trailer has videos that had a lot of helpful tips as well. So... I would definitely advise reading/watching those and looking over the dealer install afterwards.
2006 Ford F-350
Old 03-12-2016, 08:19 AM   #6
yetavon's Avatar
US TOO!!!!! 5 years, 2 campers, 3 trucks...
Once set up its very easy to use.
Rock solid feel when on the interstate with cross winds and big rigs.
As other have said review and understand how it should be set up so you know its right and adjust it if needed.
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 03-12-2016, 09:32 AM   #7
MtnGuy's Avatar
Big time agree with that post. When I left the dealership with my setup, the dealer had only put back 60 lbs. of my "lost" 300 lbs on my steer axle. The dealers are notorious for not taking their time with the setups. I also had to move the cam brackets further back then what they had dealership had done.
The get the best possible performance from the straight line dual cam, it has to be setup correctly. That includes the proper weight distributing, and also the proper position of the cams in the crook of the spring bars.
Also, try to size the spring bars to the predicted trailer tongue weight. Too heavy spring bars will make the ride seem stiff, and too light spring bars may not provide the proper weight distributing.
Another thing to consider is the correct Reese setup for the trailer. IMHO, the round bar setup works best for trailers with the coupler on top of the trailer tongue frame, and the trunnion bars work best when the coupler is on the bottom of the trailer tongue framer. That also goes along with many/most of the lighter/shorter trailers that sit lower to the ground have the coupler on top of the tongue frame, and heavier/longer trailers that sit higher up tend to have the coupler mounted to the bottom of the trailer tongue. Round bar setups go up to 1200 lbs tongue weight , and trunnion bar setups go up to 1700 lbs tongue weight.
I have the trunnion style spring bars on my trailer with the couple mounted on top of the frame, and have had some rub issues. The rub issue occurred when the coupler was mounted on top of the tongue frame, and the tongue frame was 6" or over. My trailer has both of those, plus my trailer tongue frame is not exactly parallel to the trailer frame.....it comes up in front. Going to a 2" raised ball helped with clearance some (per a call to Reese), plus 1 of the newer head assemblies (supplied by Reese after 1 of the trunnion sockets "stretched") with a raised platform helped.
Old 03-12-2016, 09:53 AM   #8
asquared's Avatar
I had the reese dual cam on my old TT. It has integrated sway control. It is a pain to dial in but once set up correctly, it is a good hitch. Know that you will likely need to adjust the setup once the tt is loaded. Take the time to understand how the hitch works. My dealer set mine up completely incorrectly including installing parts backwards.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 03-12-2016, 09:59 AM   #9
Reese DC has a "additional advantage" over Equalizer by having a "Mechanical Cam Detent system" as well as the Friction to Help arrest SWAY also! Youroo!!
Old 03-14-2016, 11:38 AM   #10
thebrakeman's Avatar
There are lots of WDH kits available now with integrated sway control. Of those that are reasonably priced, the "Equal-I-zer" brand, and the Reese Dual-Cam probably have the most history, and are well-known on sites like this. You will find very few people who have used either of these who changed to something else.
And yeah, if it seems like it's not functioning well, the dealer probably spent little time on set-up. Make sure they include the instructions, so you can take some front wheel-well measurements yourself (before hitching up the trailer, vs after engaging WDH).
thebrakeman is offline   Reply With Quote
Old 03-15-2016, 07:23 AM   #11
With our previous 32' travel trailer I had a standard weight distribution hitch with friction sway control. We just bought a new 37' and I upgraded hitches to a Reese Dual Cam. Like previous posts have said its a pain to get truly dialed in. I'm almost there. You certainly can feel it trying to keep you in a straight line, which sometimes can be quirky, but I think it's just me getting used to the new hitch and trailer.
Definitely keep all the paperwork and don't be afraid to measure and readjust things if needed. The last adjustment I made was a very minor 1/4" adjustment on the angle of the hitch head that improved things.
Nosedive is offline   Reply With Quote
