09-04-2010, 11:21 PM
Reese Dual Cam Question
We just did our first week with the new trailer and it is also our first time ever towing a travel trailer. Overall the truck appeared to do ok and I had no real issues. When we came back, I went to a scale close by our home to weigh everything and then took the trailer home and went back again with just the truck to weigh it unhitched. The front axle was approximately 150 lbs lighter when the trailer was hooked up to our Expedition. I was also not overloading my rear axle.
I am going to do some adjustments on the hitch to transfer more weight to the front axle and my question is, how much weight should I expect to transfer to the front axle by shortening the chains by a link? If I find after shortening the chains up a link, that I have moved too much weight to the front axle, can I adjust this some other way with my hitch? Now that we have the trailer loaded up pretty much the weigh we would like it, and also know we are ok with the weights, I want to get things setup correctly. I plan on going back to the scales this weekend, as the fella that owns them said I can use them and take my time to weigh everything. So I plan on measuring the drop on the front and back accordingly. We calculated that I had 900 lbs on the tongue and the trailer weighed in at 7350 lbs. I read on the Reese documentation, that I should have a minimum of 5 links, I currently am on link 6, so if I take it down to link 5, will I be ok, or do I need to adjust the angle (sorry I do not have the correct terminology for all this) of the head?? to gain access to more links?
Also, when tightening up the chains, the documentation said you should be able to lift it by hand, without the bar, as that is how much tension should be on the chains, when you have lifted the tongue and trailer with the trailer jack. Is this correct, or am I misreading this? The reason I ask, is that I certainly could not lift that hook by hand, without the bar. It also states that the hook should be level and that you then hook the appropriate link on the chain, onto the hook. In order for me to latch onto the 6th link, I had to have the hook down, so I just am not sure if I am doing this properly. If I do it when it is level, I would latch onto the link 7, and then the front end of the truck feels like it is floating. Hopefully I have not confused everyone here
Best Wishes,
Chuck
2010 Ford Expedition EL 4x4
2011 Prime Time Tracer 3150BHD
1 Lovely Wife
3 Energetic Wee Boys
09-05-2010, 06:28 AM
Chuck, I ALWAYS use the bar to lift the hook!!!
Try one more link on the chain to get more weight on the front
end.
It won't make a huge difference in front axle transfer so I think
you'll be ok. One link isn't a real big difference so go for it.
The only time I can lift my hook with my hand is if I've got
the trailer tongue jacked up with my tongue crank.
If you mean you have 6 links dangling when you're hitched you
might need to change the angle a notch.
Others will have their opinions I'm sure!!
Peace!
Dan & Rita D
09-05-2010, 07:17 AM
In reading your post, it sounds like you have a pretty good understanding of your hitch. You are correct that you can increase the pressure on the hitch in 2 ways; another link or increase the angle at the hitch head. If you are 150 pounds lighter on the front axle with the trailer hooked up, you are definitely not transfering enought weight to the front. We have found that it is important to get enough weight transferred to the front. The truck steers better and there is less "bouncing" at the rear on less than smooth roads. I personally don't worry quite as much about the number of links because of the dual cam. The links go to the cam and not to the ends of the bars. Without duam cam, the number of links becomes more critical as then the chain needs more slack to go back and forth with the bar ends. With dual cam, the key is to make sure your bars and trailer frame don't interfere with each other.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
09-05-2010, 07:23 AM
As for using the bar to hook up, like KyDan, I always use it. Think about it. When the WD is in use, hooked to your truck, trailer level, there is a LOT of pressure on the WD hitch. No way you can hook up by hand. As KyDan suggests, you would have to raise the tongue very high to be able to hook up by hand; in essence having no pressure on the hitch while hooked. There is a reason they provide that hooking bar so go ahead and use it.
09-05-2010, 08:56 AM
Wanna Be Camper
John & Deb
2011 Flagstaff V-Lite 30WRLS
09-05-2010, 08:12 PM
I think I was getting the install instructions confused a bit, regarding the lifting the chain by hand ;-) .
Looks like the dealer totally fudged up the install of the whole Reese Dual Cam hitch from what I can tell, hoping I am wrong, but does not appear so. First thing that bothered me was that the ball on the truck was almost 6 inches higher than the tongue on the trailer (when the trailer was sitting level). Today I spent the day weighing things and adjusting the chains to see the effect and then I noticed that the hitch head itself, was crooked, in that they had it torqued down with one more tooth showing one side compared to the other. I was then looking more closely at the install instructions and seen that the cam is supposed to rest square in the middle of the curve on the trunion bar, mine rests 1/2 inch away from the tip at the end and never goes into the detent part of the trunion bar. According to the instructions, the cam arm assembly is supposed to be mounted approx. 19 3/8 inches back from centre of the coupler, mine is almost 26 inches back. There is no room left for adjustment on the cam to shorten it up and put it into the detent. Bugs me as well that I now have 4 holes drilled into the tongue on the trailer frame and they will need to drill 4 more in to relocate this whole thing. Needless to say I am not very happy . I hope I am wrong on this whole thing, but after all the reading and research I have done, it appears that this whole install was bad.
The only good to come from this is that I am a whole lot more knowledgeable about this whole hitch and I did get the truck to squat pretty evenly from front to back. The front went down 10mm and the back went down 15mm which was good. I still did not get as much weight up front as I would have hoped to get there, but maybe I am expecting too much? With 884 lbs on the tongue, I transferred only 199 lbs to the front and 685 lbs to the rear axle. Does this sound ok?
Wish me luck next week in getting this sorted and I bet the truck will handle a whole bunch better once this is setup correctly.
Best Wishes,
Chuck
1 Lovely Wife
09-06-2010, 07:01 AM
Like you, my dealer did not set up my Reese Dual Cam according to the directions either. But mine was setup where I can get the cams into the bar indents. I have done a lot of tweaking to get my trailer towing sweet, but it was well worth it.
If the cams will not go into the indents then you will have to move the cam mount. I would insist that the dealer do that, since they messed it up in the 1st place.....this time show them where it should go. But to save drilling an extra 2 holes, you might have 2 alternatives. #1 is see if reversing the cam mounts from 1 side of the tongue to the other will give you the adjustments that you need....the yoke bolt is mounted off center of the mount, and depending on which how your the yoke mount is installed that might give you the adjustment that you need......or make it worse. #2 possibility if #1 won't work, is to use 1 of the existing bolt holes and just drill 1 more extra per side as you move the mount.
In my case, I have the ball mount tilted back as far as it can go. I have the worst case scenario for a Reese Dual Cam trunnion bar set-up.....a 6" trailer frame with the coupler on top of the frame. A round bar setup would have been better for my trailer to keep the cam from rubbing the trunnion bar during a sharp turn.
The ball being 6" high is probably too high. Usually, an inch or 2 is sufficient to allow a little settling so that your truck will ride level.
As far as to how much weight 1 link of chain will transfer to the front end, there are a lot of variables there, like the stiffness of the bars and how far they are already bent. Looking back through a couple of my adjustment recordings, I have had as little as 60 lbs. and as much as 140 lbs. additional weight transferred to the front of the truck with 1 link less.
After you get the trunnion bar indents seated into the cams properly, and the minimum 5 lengths of chain used won't give you enough weight transfer, then you might need to tilt the ball mount back another notch. Being that the ball appears to be several inches too high now, moving the ball mount down to the next set of holes will probably give you the weight transfer without having to tilt the ball mount back further.
Nice catch on noticing that the spacer didn't have the same number of notches on each side......that is very important to not putting the whole thing in a bind. The dealer service people are trying to maximize their time trying to get as many trailers out of the door, and don't spend the time they need to setup these things properly. Seems like you have a handle on things, and getting it done right. I have gone through the same type of adjustments, and it is all worth it when towing down the road.
09-06-2010, 07:29 AM
Yikes! What a horrible install. And you understand your Dual Cam better than the dealer! Your ball height has to come down if your trailer is ever going to be level. Good luck. Make sure to report back to us on how this finally all resolves for you.
09-06-2010, 08:35 AM
I have a question about the ball height relative to the trailer tongue. I read that the ball should be 1/2 to 1" higher than the trailer tongue, but where are these measurements taken from on both?
With the hitch install, I will be sure to keep everyone updated. I am going to take a bunch of photos of before and after as well.
Is is also normal for the top back part of the ball to be chewed all to heck after only about 320 km total towing? Looks like it was beaten with a hammer. The one cam is Aldo showing wear, as it has metal ground off, as do the end parts of the spring bar, the part that was riding on the cam that was not supposed to be. I just hope this whole assembly is not junk now. Reese even states in bold letters that misaligning the teeth can strip them.
I know the head guy that normally does the install had a an accident in the shop and had to go into the hospital, so I am hoping that is why this is why it was all fudged.
Best Wishes,
Chuck
1 Lovely Wife
09-06-2010, 09:09 AM
Best Wishes,
Chuck
Get a nice level parking lot, level your trailer (measure frame front and rear to the pavement) and measure to the top of the coupler. Set your ball height about 1" above that. When you hook up the trailer, the rear of your tow vehicle will drop some, and hopefully level everything. My truck rides about 1" lower in back with the trailer than without after pulling up the WDH.
My ball has gouges also. A local trailer shop said that happens, and he has seen much worse. I wonder sometimes if they tow from the factory without greasing the balls, damaging the coupler. I grease the ball well before towing now, and haven't noticed much additional damage.
Your cam will show wear also, but not sure how much you have after 320 km. When you get everything set up properly, mark the spring bars so that the go back on the same side every trip. That serves 2 purposes: 1, just in case the spring bars are not the exact same length, using them on the same side every time will let them fit exactly on the cams to keep your TV straight. 2, using the spring bars on the same side every time will allow the cam and the spring to "seat" the same every time you tow.
Also, use Vaseline on the cam and spring bars....that will help with the noise, and maybe lessen the wear. Do not use grease there.
09-06-2010, 07:04 PM
Unfortunately I cannot flip the cam mounts, as that would move things back even further . From the measurements I took, it appears I will need 2 new holes and will deal with that one way or another. Thanks TheSasks for the link to the setup guide. And acadianbob, you sure are right in that with the front end being lighter, things were not right. At least I believe I have that part sorted and a much better understanding of how things should be. With the tests I did yesterday, it put weight on the front end and I guess more importantly??? is that the vehicle squatted fairly close on the front and the back.
mtnguy, my frame is also a 6" tube frame, with the coupler on top, why is that not so good? I also believe I will need a different coupler, as if I move the ball to the lowest setting on it, it will still be too high in comparison to the trailer and have it in a nose up position when towing. I have not taken more measurements yet, but with the trailer level when hooked up to the truck, I think everything will be fairly close to the ground, perhaps this is what you meant by this 6" frame with the coupler on top not being the best. When you mention tilting the head back. are you meaning back as in the top towards the trailer?
Say I need more links available, would tilting the head back, give me more links to play with? And am I correct in assuming that for example, if with the head in the current postion, I was on link 4, that if I tilted the head back?? that I would basically get the same effect on link 7? Hopefully I am not making this too confusing, as it is hard to explain. Just trying to get a good grip on the relationship of the head angle, chain adjustments and how this effects things with the transfer to the tow vehicle.
The amount of wear I am referring to, does not appear to be normal. With the way things were hooked up and twisted, the spring bars look like a grinder was taken to one side of them. One of the cams also has a flat spot and is ground down pretty good.
When I picked up the trailer, the roads home were all straight so I never got a real feel for how things felt when driving, but the truck pulled the trailer quite good. What I did notice is that it was like riding a bucking bronco, not so good, but with nothing to compare it to, I thought this was to be expected. I then talked to a couple other people and they said they do not experience anything like this, so I started to look a lot more closely at things. When going through a set of curves, the truck felt like it wanted to keep going straight and the front end could easily loose steering control. So thanks to the forums here, I recalled people saying to tighten up the chains, which I did and immediately I noticed a HUGE difference in the steering and how things felt. But I think I have a long ways to go yet, to get this thing properly setup, consider how bad the install was.
I do have one question that comes to mind right now. When you are driving in a straight line, doing 80 kmh (50 mph) and you take the steering wheel and give it a left to right wiggle, how stable should things feel? Right now the truck feels like it is not in control and I would not dare want to do an evasive type manoeuvre at those speeds. I realize that a lot of the problems are due to how bad the setup for the hitch is at the moment and also the fact the truck is running the stock P rated tires. I am planning on changing the tires out to LT ones after the winter, as they have a lot of tread and the trailer season is almost over right now. I am just not sure what I should expect for handling really, regarding how it should feel in curves or when you wiggle the steering wheel?
Many thanks,
Chuck
1 Lovely Wife
09-06-2010, 09:58 PM
Tilting the hitch head back (toward the trailer) will increase the pressure on the bars for the same number of links. So, yes, tilting the head back toward the trailer will give you more links.
Ball height; do you have a good adjustable ball mount like one of these?
Adjustable Ball Mount Ball Mounts | etrailer.com
It is imperative to get the top of your ball about 1" higher than the top of your coupler when the trailer is level. If the ball is too high, your trailer will never be level. It will be nose up and this will tend to induce sway. Another reason your trailer needs to be level is to get even loading on both axles/tires.
If your truck steering feels too touchy, I'm thinking that you are still too light on the front end/too heavy on the back. This will cause you to feel like you don't have adequate steering control. I think this is what you are trying to describe. Another sign of too little weight on the front (and too much on the back) is your description of bucking like a bronco.
My setup is solid as a rock whether meeting a semi on a 2-lane, in a curve, or in big cross-winds. And I am running P-metric tires.
I think you have several problems; ball height, inadequate pressure on the front of the vehicle, and trunion bar indents that are not properly seated on the cams. ALL of these problems will lead to instability.
By the way, even properly adjusted cams will show signs of wear over time.
09-06-2010, 10:31 PM
I just looked up specs on your trailer and it is pretty hefty! What is the towing capacity on your Expedition? And what is your wheelbase? Another issue may be that your tow vehicle is at the upper limits of its capacity. You are at 34 feet and are no doubt over 7,000 pounds.
09-06-2010, 10:41 PM
According to the Ford website, your wheelbase is 131" on the EL. With that wheelbase, guidlines suggest that you should only be towing about 25 to 26 feet. The same website lists your towing capacity at 6,000 pounds; unless you have the heavy duty towing package at 8,700 pounds. If your signature is accurate, you may have a tow vehicle capacity issue. I'm also trying to understand why you are having so much trouble getting your ball height to the proper level. We tow with an F150 which should be similar and have had no problem with that. You can turn the ball mount upside-down. Hope this all helps.
09-07-2010, 06:35 AM
Grape Escape
And where does the manuf website state you should only be towing 25-26'?
Love all the misinfo members hand out.
Should he be towing with a stretch limo?
Lets not put the fear of god into this.
He was not asking if TV was suitable.
If an Expedition is not suitable I don't know what is.
Your Table is flawed big time
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
09-07-2010, 08:27 AM
The trailer length guideline I was referring to is not from the Ford site. The most commonly accepted guideline is 110" of wheelbase for a 20 foot trailer. Then, for each additional 4" of wheelbase, you can tow another foot of trailer. This guidline would suggest a trailer length of 25 to 26 feet for a 131" wheelbase. A 34 foot trailer is well in excess of that guideline. The combined gross vehicle weight for an Expedition is 12,000 pounds (15,000 if heavy duty tow package). This is a 7,000 pound trailer by the time it is loaded I would guess. An unloaded Expy must weight 5,000 pounds. My F150 is 5,700 empty. While I realize that the OP was not asking about his tow vehicle, it seems to me that the upper limits of the tow vehicle are potentially being pushed or exceeded. I brought it up because this could also be a source of the instability he is feeling. If my specs, calculations, or information are incorrect, my apologies. Factually based information that offers other conclusions would be welcome. My primary obective is to be helpful and to make sure everyone is safe.
09-07-2010, 11:22 AM
Flumpydog, in answering some of your Reese questions, I failed to notice your tow vehicle and trailer combination. Everyone has opinions what is best to tow what trailer, so I will add mine. That is a long trailer for a Expy, and the weight could be a problem, also. Check out the tow limits of your Expy here: https://www.fleet.ford.com/showroom/...rMntrMarnr.pdf
Now to answer a few of your questions:
Check out these 2 articles: RV.Net Open Roads Forum: Towing: Travel Trailer Hitch Set-up Procedure & RV.Net Open Roads Forum: Towing: Reese Dual Cam rub The 1st is more on the Reese Straight Line setup, and the 2nd is on the Reese trunnion bar rub problems. The rub is a problem when you have a 6” frame with the coupler on the top, and using the square bars……the round bars present no problem. My setup was hitting the yoke bolt, and after conferring with 1 of the knowledgeable members @ RV.net and Reese techical support, I had to got with a 1” raised ball so that the yoke bolt rode higher than the spring bar…….but it will still hit the yoke during a extremely sharp turn.
With that long of trailer, I would think that the couple should be fairly high off of the ground. If your hitch now looks like an “L”, trying flipping that so it will look like a “7”. I had to flip my hitch from the dealer setup to make things work correctly height wise.
Pictures would be be nice.
You will get more bounce towing than not towing….That is nature of the beast. The spring bars should be sized to the tongue weight of your trailer. A listed 595 lb. tongue of that trailer would suggest 800 lb. bars, but ready to go camping that figure might be over 800 lbs., meaning 1000 lb. bars (round) or 1200 lb. bars (square) might be in order. What sized bars did the dealer set you up with ??
The instability that you are feeling happens when you tow. The trailer is trying to push the tow vehicle. How much you are feeling, I have no idea if that is normal or not. Again, that is a lot of trailer for an Expy, and that might be some of the problem. Also, a properly setup Reese Straight Line Hitch will try to keep you straight. I feel it going into a turn. Equalizer and friction controllers will tend to keep you whatever angle that you are currently in, where the Staight Line will tend to do just that….get you back into a straight line. Either Reese or Equalizer type systems work great when properly setup, they just control sway in different ways.
09-07-2010, 01:19 PM
The manufacturer wont tell you this it has to be figured out using facts and figures. The manufacturer wants to sell you a vehicle they don't give a rip about what you do with it or that you do it safely. RV dealers won't tell you either as they want to sell RVs.
So if we throw out facts and science then lets just tell anyone they can pull anything with any vehicle, that would make for a wonderfully safe holiday weekend.
So far I have seen no information handed out that is incorrect by Bob but I have seen others here saying "go ahead pull that 35' 5er with your f150" That IS misinformation.
I have seen first hand the aftermath of a friends sister who balled up her brand new trailer because no one like Bob was there to tell her she shouldn't be pulling the trailer with her short wheelbase vehicle even though it was under the "weight limits" for the TV. She's lucky to be unhurt after he accident.
Yes the OP asked if his TV was suitable, based on sound facts and figures the information he asked for was given. Some of you need to leave machismo and the "my truck can pull anything" attitudes at home and start thinking of safety, otherwise lets just tell people it's fine to pull a 33' TT with a Subaru wagon!
09-07-2010, 02:52 PM
Grape Escape
More often than not trailering accidents occur due to inexperience not the tow vehicle wheelbase. I would not even consider allowing many of my friends to get behind the wheel pulling any trailer let alone mine. Many inexperienced people buy a rig without even considering that driving is totally different with a trailer in tow.
As for wheelbase I personnally towed a 28' trailer with a 2001 Pathfinder(Oh no with that short wheelbase) as well as with a Chevy Tahoe (another short wheelbase vehicle) without any problems whatsoever for many miles as long as my Dual Cam was set properly and proper tires.
I am sure auto manufacturers would put legal disclaimer into manuals with all the legal ramifications about max trailer vs wheelbase.
Look on the roads. See how short wheelbases are on 18 wheelers pulling 45'trailers.
09-07-2010, 03:23 PM
Yep and just like drunk driving you may get home 50 times in a row with "no problem" but one of these days your luck will run out and your gonna wrap it around a tree. I just hope i'm no where near you when you do as I don't want you taking me with you.
