Old 07-18-2012, 10:37 PM   #91
B47
Originally Posted by f1100turbo View Post
mine locks with a padlock when latched to keep from coming open .
Isn't this similar to the mod that Herk was talking about recently that he installed?
Old 07-18-2012, 10:55 PM   #92
B47
Originally Posted by Snowsail View Post
Here are the instructions.
Where in these instructions does it show or mention some sort of a lock to be installed after hooking up? I see nothing in the parts list or the instructions.
Under the "Unhooking Procedure" it says in step 6 "Remove bail pin from hole in handle." Is this the so called lock that some of you mentioned?
If it is, then I guess you don't install the lock, but be sure to remove it before unhooking.
Old 07-19-2012, 08:51 AM   #93
First off, those are the instructions for the Sidewinder Pin Box, not the 16K Hitch. There is no lock on the pin box. The lock is on the hitch itself.
Old 07-19-2012, 08:53 AM   #94
No, Herk was talking and showing a pin catcher in the case the latch inadvertently does not latch and the pin being caught before it drops down and damaging the truck & trailer. Page 7 figure 16 shows the latch closed. You put the padlock in the closed latch which locks the handle from being pulled out.
Old 07-19-2012, 11:06 AM   #95
B47
Thanks - I see the latch, but the instructions or parts list doesn't mention or show a lock being installed and being a guy who believes that instuctions should do just that - instruct.
However, I now believe I know as much about the Reese Sidewinder and associated hitch as I want to I won't be posting on this thread again.
Thanks again.
Old 07-19-2012, 11:08 AM   #96
TURBS's Avatar
Thanks again.
Instruction manuals are just another mans opinion. Imo respectively!
Old 07-19-2012, 11:25 AM   #97
B47
Well at the risk of breaking my word, I must say that in the world of U.S. civil avaiation aircraft maintenance ( and i believe military maintenance also) that your opinion could cost you fines and possible suspension or revocation of your FAA mechanics certificate (if you had one) and in the most extreme cases jail time by not following instructions furnished by an aviation manufacturer of parts or an aircraft builder when performing maintenance on a U.S. registered civil aircraft or component thereof.
I have personally been involved as a FAA maintenance inspector in bringing enforcement action against persons and corportations doing maintenance and not following the manufacturer's manual instructions or the air carrier they were employed by and not following the manual.
I will not go into this any further here, but if you want to PM me I will show you the rules.
Old 07-19-2012, 11:32 AM   #98
Wow, 1st ammendment just got thrown out the window with the U.S. civil aviation. f1100 you can't even have an opinion with those dudes.
Don't really see the correlation between the U.S. civil aviation and a simple latch on a hitch and a padlock.
Maybe f1100turbo understands.
Old 07-19-2012, 11:37 AM   #99
TURBS's Avatar
I'm just going to giggle out loud!
And thank god I'm breathing today!
Without the humor from frf id be lost.
Old 07-19-2012, 01:11 PM   #100
Theres a manual ? Why ? The dealer knows it all and shares that knowledge during the non stressed first time you hook up at the dealer with absolutly nothing else on your mind at the time. Manual shmanual.. Trust the dealer... from manufacturers mouth to the dealers... ok I will stop. All that to say I never knew there was a manual until I went on line.
Mike - Ottawa
'10 Rockwood 8280ws
2014 Ram 2500 SLT HD Crew Cab 4X4 3.73
Mike101 is offline   Reply With Quote
