Old 01-11-2016, 12:22 PM   #11
Canadian Member
itat's Avatar
It's interesting to hear all of you using the Sidewinder/Revolution pinbox with a 5.5' box. I was told it's not recommended for anything less than a 6.5' box.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 01-11-2016, 12:28 PM   #12
pontiacdan45's Avatar
Send a message via Skype™ to pontiacdan45
I'd say the only think to look at are the previous posts about using the wedge, lubrication and torque of the mounting bolts. Everything is posted in the library on this site, including diagrams. I've had mine with a 8289 ws since 2014. Initial issues hitching and un hitching were due to my inexperience, but common for many users. Sure pulls straight and great.
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
pontiacdan45 is offline   Reply With Quote
Old 01-11-2016, 12:38 PM   #13
Cool Reese revolution pin box
I am very pleased with the added manoeuvrability this style of hitch provides. However, there is one very annoying issue I have with mine. It squeaks and squeals as it moves. I have tried squirting lithium Grease into the plate where is moves but nothing works. Anyone else have this problem?
Chuck
8288WS is offline   Reply With Quote
Old 01-11-2016, 01:14 PM   #14
Go up on youtube and check out the REESE videos on the Revolution/Sidewinder. It will dispell a lot of misinformation about this pinbox including the one about not being compatable with Curt hitches.
Strigflag is offline   Reply With Quote
Old 01-11-2016, 01:23 PM   #15
B and B's Avatar
I have it, hitch replaced free last year at goshen due to a seized pin. Works great! Need to keep it lubed and not dry like some people here say, direct from Reese techs.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 01-11-2016, 04:30 PM   #16
Long Leaf Piners's Avatar
Revolution pinbox broken wedge nut weld; not repairable.
We traveled with a SuperGlide for several years with an Alpen Valhalla and at 14k, it pulled like a dream with our shortbeded F250. Traded to a 2014 Flagstaff 8528IKWS--lighter, but equipped with the Sidewinder/Revolution pinbox...so we traded out for a 14K standard hitch.
While the Superglide was always easy to hitch up on the Valhalla, the Revolution required a very lined up orientation in order to lock in clearly. We had learned to work with this, but found it to be an on-going hassle.
But, ultimately (by May, 2015) the pinbox actually sheared a welded nut inside the nose of the Revolution pinbox and we could only tighten one of the two bolts for the wedge. Under tow, this broken nut could have lead to two swivel points on the hitch & pinbox--and untenable situation.
We were stranded, but near Tom Johnson's in Marion, NC, where we had originally bought our Flagstaff.
So, under their advice, we unhitched & locked the Revolution back into its "Transport" mode--basically turning it back into a standard pinbox. In order to tow, we ultimately replaced our 14K Reese with a new Superglide (now smaller and fitting on the already installed universal bed rails) and continued traveling extensively through October, 2015. Easier to hitch, pulls easy, straight, and confidently.
I just felt you needed another view of the Revolution--Tom Johnson's repair group said that they had seen that shearing of the welded nut only once or twice before.
2014 8528 IKWS
Ford F-250 Diesel
Cricket the Cairn and Sally the Terrier Muppet Mix
Long Leaf Piners is offline   Reply With Quote
Old 01-11-2016, 04:37 PM   #17
Left Coast
Same thing happened to Glenn J. awhile back. Sent him a new pin-box
Old 01-11-2016, 04:40 PM   #18
PhoneDude 8289's Avatar
X2 on all the above.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 01-11-2016, 04:43 PM   #19
DAISY BOYKIN's Avatar
Just Installed----------------
Just installed the Sidewinder pin box on my 2011 Rockwood. Had to modify
the existing bracket on the camper by cutting off about 3" of the RV brackets in order to get the 6" clearance between rails and bottom of camper. I had used a Super Glide hitch in my F-150 which weighs close to
400#. When I upgraded my TV to a F-250, I decided to go with the sidewinder pin box. The 16K hitch in my F-250 weighs 1/3 what the Super Glide does. Pulls great with the sidewinder Pin box. I can remove the 16K Reese hitch very easy form the bed of my TV now.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
DAYS CAMPED 2018 21 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 01-11-2016, 05:10 PM   #20
Left Coast
Did you pick up more turning clearance? (over the Pull-rite)
