Old 08-24-2016, 01:19 PM   #21
Kaadk's Avatar
Originally Posted by itat View Post
...I just talked to a guy at the nearest highway weigh scale house operated by MTO enforcement and he confirmed what the dealer is telling me. I'm exempt from the CVOR, daily inspections and log book requirements because its a personal use vehicle, but if you're towing a trailer that weighs more than 6171#, you need to have the yellow sticker saying you passed an annual inspection.
That's what you need to do to be legal. So all you folks in Ontario that pull 5ers and longer TTs are running illegal if you don't have the yellow sticker. Before this I had no idea that was the case....
So, based on that, towing my 5840 lbs dry weight TT (so probably over the 6171 lbs no matter how lightly it's loaded) means I need to annually certify my 1/2 ton?
In fact, I'd say based on a 6171 lbs limit, pretty much every trailer (except maybe some pop ups and a frames) are going to be over that limit. When we were looking, it wasn't just longer trailers, some of the hybrids we considered were in the 20ish foot range and still 5k+ dry weights.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 08-24-2016, 01:32 PM   #22
Canadian Member
itat's Avatar
My previous 2010 Roo 23SS scaled at 5200# ready to camp so I think most hybrids and MiniLites are under the threshold. Most, if not all, 5ers and 27'+ TT would be over and require annual certification. As DDC said, ignorance is bliss and cheaper.
All of this only really matters if you get pulled over by the MTO and weighed. I have no doubt most FRF members don't jeopardize the public with their setups. And I seriously doubt that MTO enforcement really cares much about any RVers except the most obviously overloaded trucks.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 08-24-2016, 01:58 PM   #23
B and B's Avatar
My dealer gave me a choice to debate to 7500 lbs or go for 9900 lbs which I did.
I think you are making a mountain to climb here rather than just registering at rated weight.
The key is recreational vs commercial. Even a boat or utility trailer with quads can be considered recreational use.
B and B
2017 Heartland Bighorn 3575 Elite
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
"Oh Canada,True North Strong and Free!"
Old 08-24-2016, 02:10 PM   #24
Wanna Be Camper
SaskCampers's Avatar
Sorry, I gave a wrong number for the "brochure curb weight". 3000# is the published payload number. Ford doesn't seem to publish the "base curb weight" but they do specifically say "Payload = GVWR - Base Curb Weight" so Base Curb Weight = GVWR - Payload = 9900-3000 = 6900# for a CC with the gas engine. It seems reasonable for your Lariat trim to add 432#. My XLT would probably be closer to 375# over base weight.
Look at the sticker inside on the drivers door pillar. It will show GVWR and payload for your particular truck that will take any questions out of the equation.
OH BTW..
Congrats on the new truck, you will love it.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2013: 16 2014: 5 2015: 3
Old 08-24-2016, 02:58 PM   #25
Canadian Member
itat's Avatar
Brian, that's what I thought too but after looking into it, the Regs and the MTO disagree with us.
For all the typical commercial vehicle stuff (CVOR, daily inspections, log book) you are exempt. But for the annual inspection requirement, it doesn't matter that its a private use vehicle - its about the weight of the vehicle and the weight of the trailer you're towing.
The Regulation says that if you exceed either threshold (vehicle weight of 4500 kg or trailer weight of 2800 kg) you are supposed to do the annual inspection. Period.
Fondly remembered:
Old 08-24-2016, 02:59 PM   #26
Canadian Member
itat's Avatar
OH BTW..
Thanks, John.
Fondly remembered:
Old 09-15-2016, 04:22 PM   #27
I can speak from experience that itat is 100% correct - MTO does not care if the TV or trailer is commercial or not - you need the yellow sticker on both vehicle and trailer - and the inspection is very rigorous
dthomso1 is offline   Reply With Quote
Old 09-15-2016, 04:57 PM   #28
W5CI's Avatar
So are you guys saying that if I pull my 12000 lb Cedar Creek thru Ontario with my RAM 3500 DRW which has $27 Arkansas tags on it I am going to get fined, I don't think so but i may be wrong. the trl has a $35 permanent tag on it. No weights mentioned anywhere and no inspections required here.
2004 Cedar Creek 30RLBS MORryde IS/Disc Brakes
2015 RAM 3500 DRW 6.7 Cummins 3.42 Garmin 760RV
Firestone Air Bags/Air Lift Wireless One Controller
40 Gal TransferFlow fuel tank
Amateur Radio W5CI AR-0043-29 2016 Days Camping 50
2017 Days Camping 8
W5CI is offline   Reply With Quote
Old 09-15-2016, 04:59 PM   #29
Can someone point me to the legislation that says a rv needs to be inspected. In every thing I can find private rv's are not included.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 09-15-2016, 05:04 PM   #30
B and B's Avatar
I would agree. Whomever gave their opinion is in error from the government.
My truck is licensed at 9,900 lbs. 4490 kg.
B and B
