Old 09-15-2015, 12:08 PM   #1
blwnsmoke's Avatar
removing 5th wheel hitch - keep attached to camper??
We bought our 1st 5th wheel last October and I've kept the hitch in my bed the whole time. There have been a few times where I have wanted to use my bed but at over 300lbs, I would have to disassemble it into pieces to remove myself as I don't have a winch.
Then I drove by a 5th wheel on Sunday that had the hitch locked onto the 5th wheel itself hanging there. I remember a discussion last year that I read about some people doing this and completely forgot about it.
Are there any cons to leaving your 5th wheel hitch hooked up to the 5th wheel? I have the Ford 5th wheel prep package so I only have to turn the 4 points 90 degrees to unlock it from my bed and then just lift the 5th wheel up lifting the hitch out of the bed.
Thoughts??
2015 F350 6.7 Platinum
2015 Coachmen 360IBL
blwnsmoke is offline   Reply With Quote
Old 09-15-2015, 12:13 PM   #2
Rugged Brown's Avatar
I can't think of any cons, probably theft , but otherwise give it a try.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 09-15-2015, 12:24 PM   #3
MilCop4523's Avatar
theft would be the little one I am worried about
if they bolt cut ground and some live wires out of substations we own a small padlock which locks the slide handle to release the jaws is no match.
i think i'll buy 2 frineds with huge arms a few beer and get them to muscle it out of the truck bed, or off the pin when lifted up.
i could also use my tractor - once the water pump is replaced next week.
09 Sundance 31.5 XLT Bunkhouse
17 Greywolf 22rr Toy Hauler
and
The new toy hauler - 2016 Ford F150 Supercrew XTR ECOBOOST.
MilCop4523 is offline   Reply With Quote
Old 09-15-2015, 12:48 PM   #4
blwnsmoke's Avatar
I'm not really worried about theft so if that is the only thing that you all can think of, I think I'm good to go. Besides, it would only be removed for a day or two worst case while I use my bed and then hook it back in. I plow in the winter so the added weight to the rear helps out a lot so I don't have to put sand bags back there.
I live in the middle of no where, down a long driveway with only 6 houses on my street in the middle of a State Park. We really see zero traffic where I am besides the few neighbors I have.
I was more concerned with any effects that it would cause to the camper with the weight dangling on the 5th wheel itself but I guess 300lbs is not much.
Old 09-16-2015, 11:34 AM   #5
Tucson Joe's Avatar
What hitch do you have that weights 300 lbs? I have a 22000 hitch with the safety arm attached and I can pick it up, it is heave but not over 100 to 125 lbs.
2014 Ford F450 4+4
2009 XLR 40X12
2009 RZR ready for the trail
2014 RZR XP 1000
Days camped in '16 - 87
Days Camped in '17- 62
Tucson Joe is offline   Reply With Quote
Old 09-16-2015, 11:43 AM   #6
blwnsmoke's Avatar
I have a Demco slider hitch (have a short bed and wanted to make sure I wouldn't have issues). Shipping weight is 289lbs (thought it was 309) so minus the cardboard, you are talking 275-280lbs.
Old 09-16-2015, 11:56 AM   #7
2Vals's Avatar
Thoughts??
What came to mind about leaving the hitch attached was when you go to re-attach it. Seems like it would be a bit of a bear lining up the four bolts as you back your truck under the dangling hitch?
On the weight issue as the hitch is attached to your 5er - I would think one of the hitch supports might help in that regard. I have one we rarely use that I am thinking of selling currently.
Anyway, good luck on your quest.
2015 FR Salem 286RLT Hemisphere 5th wheel
F250 Diesel Laredo Crew Cab
Traveling the highways & bi-ways . . .
with our girls, the maltese pups .
Happy Trails
2Vals is offline   Reply With Quote
Old 09-16-2015, 02:02 PM   #8
Fulltime family RVer
That's exactly what I'd wonder is how much of a pain is it to get it put back into the truck. But, the folks who do it, say it isn't as bad as it would seem.
As for the weight- I say that the pin box area takes a LOT more abuse going down the road than a 100-300 pounds hanging from it.
My big fear, and a simple lock suffices- is someone getting tinkering with it and dropping it on themselves.
Old 09-16-2015, 02:50 PM   #9
We have the B W slider, quite a bit over 200# and it hung on our 5th last winter with no apparent problems. The lock or something in the locking handle is something I will do this year...
9.5 year old FR Cherokee 295 WP 32' toyhauler
2013 Ford F250 SD CC 4X4 4.30 gears
Tuned-- engine, music, and exhaust,
bpadamson is offline   Reply With Quote
Old 09-16-2015, 03:04 PM   #10
Boso's Avatar
Hanging hitch
Had super glide and did that but didn't leave very long.Made me a table same height as truck bed moved mine with 1" pvc as rollers and shovel handle it was heavy but I could put in garage and break down into pieces to do maintance or to just clear bed I also had rail that came out for clean bed
Boso is offline   Reply With Quote
5th wheel, camper, hitch, wheel
