Old 07-20-2019, 08:39 AM   #1
replace spare & add bike rack to back 2019WOLF PUP
Hi there, we just bought a new Cherokee Wolf Pup, 22 ft rv and it has the drop down platform w/ the spare mounted to it. When lowered to put bikes/storage on it, the spare bottoms out on inclines/ drive ramps etc... I'd like to remove it and mount the spare to bumper and add a bike rack, but that bumper and the under frame is pretty light weight....has any one done a mod like that?? I may have to weld some extra supports back there... THANKS!!Click image for larger version
Name:	2019 Wolf Pup.jpg
123abc is offline   Reply With Quote
Old 07-20-2019, 09:10 AM   #2
Try a BAL Hide a Spare:
Installing BAL Hide-A-Spare on a Mini Lite
2011 Traverse LT, 3.6L, FWD
Old 07-21-2019, 10:31 PM   #3
Originally Posted by rockfordroo View Post
Unfortunately, Wolf Pups are pretty low to the ground. So much that I'm considering "flipping" the axle to under the springs. I could not imagine a Hide-a-spare rig would work well. I watch my drain pipe going in and out of my drive and am within an inch or so of dragging AFTER having my driveway graded to a smoother taper to the road.
There are brackets that can be bolted (drilling required) to the frame and loop up under the "bumper" sewer hose storage tube to reinforce it. Then add in the cost of the bike rack and spare tire mount. That's why I still use my rear rack as the spare tire carrier ;( I would like to be able to use the rear rack without worrying about dragging the spare. The spare carrier is welded to the rack bottom.
2019 Cherokee Wolf Pup 16BHS
2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# spring bars
Boomerweps is offline   Reply With Quote
Old 07-22-2019, 09:01 AM   #4
My Mini Lite is also very low to the ground. The bottom of my sewer drain is only 9" from the ground.
bike, bike rack, wolf pup
