Old 01-18-2017, 11:46 AM   #1
Replacing OEM tires on new wildwood 27dbk
Guys,
I'm new here and I have a question for the group, I am not a fan of the C rated tires that came on my TT so I am looking to replace them with D rated tires. My question is would there be any benefit or negative in going from the stock 205 75R 15 to a 225 75R 15? My thought was the bigger 225 would dissipate heat better, but i'm not sure if sidewall flew would be an issue. Thanks for your help.
Jody
jodyfj40 is offline   Reply With Quote
Old 01-18-2017, 11:56 AM   #2
As long as they clear the Frame on tight turns "Tire Lean" and also clear the Top of wheel wells during suspension Travel That is what I would Do! Youroo!!
Old 01-18-2017, 12:47 PM   #3
I go RV'ing not Camping
jgourlie's Avatar
x2
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 01-18-2017, 12:48 PM   #4
Life is great's Avatar
Welcome from Lancaster PA!!
If they fit and don't find any rubbing going on during travel then go with it.
2012 Rockwood Signature Ultra Lite 8312SS riding on Gladiator rubber.
2004 Ford F350 (Black Beauty) CC, SB, 6sp, 6L work horse.
Camped
2016 - 21 nights
2017 - 42 + scheduled....
Life is great is offline   Reply With Quote
Old 01-18-2017, 01:26 PM   #5
They do make a 205/75 R15 in a D rating which would be better than your stock C rated..
According to the online charts I looked at the 205/75 R15 LRD is 27.3" diameter, 8.1" wide with a load capacity of 2150 Lbs.
The 225/75 R15 LRD is 28.3" diameter, 8.9" wide with a load capacity of 2540 Lbs.
The 225 will be just a fuzz wider and 1" bigger in diameter. (1/2" in height from axle center) and carry more load.
I'd say if it fits, I see no negative.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=64
Old 01-18-2017, 03:23 PM   #6
Thanks guys,
I'll take a look tonight when I get home and see how much room I have in the fenders and go from there.
Jody
Old 01-18-2017, 03:29 PM   #7
All of the above is spot on good advice. So take a look tonight and check in tomorrow. By then this thread should be about 25 pages long and the popcorn will be buttered.
Sent from my SAMSUNG-SM-G891A using Forest River Forums mobile app
Mr Havercamp is offline   Reply With Quote
Old 01-18-2017, 07:55 PM   #8
On the road again...
If you do move up to the 225 size an "E" load rating is available, also.
2015 Coachmen Encounter
2001 CRV Toad
Let's go campin'!
MMMH is offline   Reply With Quote
Old 01-18-2017, 09:49 PM   #9
All of the preceding advice is sound. Before making your purchase decision, however, I urge you to double check on the reputation of the tire manufacturer. It is almost impossible to find trailer tires manufactured in the US today. Nearly all come from China, and many of those are poor imitation "knock-offs" of US designs. Do not buy "Mission" Tires, which came on my TT years ago. They were imitations of Good-Year Marathon Trailer tires, and 3 of the 4 failed within 2 years of purchase. Also, be sure to check the tire manufacture date molded into the sidewall of the tires. A reputable, local tire dealer will be ale to provide you with all the pertinent information .
Jakieboy is offline   Reply With Quote
Old 01-18-2017, 10:05 PM   #10
Be sure to check the width of the rims supplied on your trailer.
They may be too narrow to mount the 225's on.
If that is the case, stick with the 205's in a LR D.
Too wide of tires on narrow rims makes for a bad mix. The tire manufactures state the recommended width of rim for each tire size.
John U
2007 Rockwood 8315SS Sold 11/19
2014 Silverado 2500HD 6.0L Sold 11/19
Back on the road 10/20
2010 Born Free 22RSK
midnightpumpkin is offline   Reply With Quote
Old 01-18-2017, 10:12 PM   #11
david_reaves's Avatar
I've had great luck replacing the stock "C" tires with a higher rating tire. In my case I was able to find load "E" tires the same size as stock. I bought them at Discount Tire, with the road hazard warranty. I did that specifically because I could pretty easily get to a Discount Tire when traveling if I had a problem. So far, though, so good.
Heat dissipation is definitely better. Last summer I was pulling through west Texas on a warm June day. The pavement was 99-degrees. When I checked tire temperature with my handheld infrared thermometer after about two hours towing on the freeway (at about 70 mph) tire temperature was no warmer than the pavement itself. Made me a believer.
david_reaves is offline   Reply With Quote
Old 01-19-2017, 07:09 AM   #12
DouglasReid's Avatar
from ALL I have read on these forums the brand Maxxis seems to have the best reputation. They aren't Chinese but made in Thailand I think. They are what we just bought and thus far no troubles
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 01-27-2017, 10:59 AM   #13
If you are going from a C to E rated tires you have a real good chance that your rims won't be rated for the air pressure of a E most c rims are rated at 65psi max.
Good luck
2nd the Maxxis tire
Rockwood 8289ws Signature 2016
2016 2500 Hd Duramax
Days camped 2016 30 nights and climbing
Days camped 2017 42 days and climbimg
pipe is offline   Reply With Quote
Old 01-27-2017, 11:11 AM   #14
All above answers are good , but , there are thousands of us out here who have no problems running our OEM tires for thousands of miles with no problems . I never change tires until needed . I tow ten or fifteen thousand miles a year , always checking tire pressure every morning and wear my OEM tires out and then I buy Maxxis .
wanderingbob is offline   Reply With Quote
Old 01-27-2017, 11:21 AM   #15
Thanks guys,
After looking under the TT I didn't feel compfortable going any taller on the tire so I decided on going with a D rated tire on new wheels that can handle the rating. I went with the Carlise Radial Trail HD tire in load D and their grey Highway wheels. I will keep the others for spares.
Radial Trail HD
tire, tires, wildwood
