Old 11-09-2015, 01:34 PM   #11
FYI
Check this magnetic connector out... pricey but gives you lots of safety and piece of mind,
http://www.ezconnector.com/
grayfox is offline   Reply With Quote
Old 11-09-2015, 03:16 PM   #12
Rivnut
Rivnut's Avatar
replacing the 7 pin trailer wire
Mine fell out of the receptacle on I-65 going to Goshen rally, draged it all the way to Goshen when somebody told me. They put a new one on for me . I tied it up now. use the small bunge cord it to the receptacle now. Can't trust them.
Rivnut
Rivnut is offline   Reply With Quote
Old 11-09-2015, 03:41 PM   #13
PhilB's Avatar
Replacing the 7pin trailer wire
Originally Posted by MilCop4523 View Post
On my first backing of a 5th wheel TT i heard a lot of crunching and snapping... DW thought it was teh truck - I thought it was the trailer axles.
She was right.
Somehow I severed the connection between the pin and the bumper and fried a 32 dollar breaker in the truck shorting the wiring out.
Not only did I cut the line in 2 pieces but I ripped the wiring out of the junction box at the trailer end.
I was kind of shocked that none of the stores locally sell 7 pin wiring and had to go to parts for trucks...
I wired the connections in 2 pieces with a round 7 pin Reese connector at the trailer end and 4 feet of new wiring.
(type that normally fits into the bumper of the truck.)
I then used marine grade Marr connectors in the junction box.
Then I took the 7 pin that fits on the bumper and left it alone at that end
On the cut end I put a female junction made by Reese (in the middle of the second piece) so the trailer male end connects the 2 pieces.
Worked out great because I also purchased a second Female 7 way to 4 way flat connector for tying into the trailer battery and run my park/tail lights when we are at the park on shore power.
I hope you determined the cause so you don't repeat.
We Travel Not To Escape Life But For Life To Not Escape Us
2012 Prime Time 230FBS Tracer
PhilB is offline   Reply With Quote
Old 11-09-2015, 04:41 PM   #14
Kenny kustom's Avatar
Originally Posted by grayfox View Post
FYI
Has anyone used this?
My new ram has no bed prep, so I thought i might give it a try?
2015 RAM 3500 CCSB CUMMINS
2016 Sabre 36QBOK
2017 Dynamax Isata 4
Old 11-09-2015, 06:37 PM   #15
2016 Sabre 36QBOK
Yes, I installed one on my 3500 GMC. Very easy install, plug and play to your current wiring harness on your truck assuming you have the tow package with the 5th wheel wiring harness. As far as the install on the trailer you'll have to remove the current wire harness install the new one, again easy install. The magnate in the connector is very powerful making a positive and secure connection. As a side note, because of the smooth contacts and strong connection the brake and running lights seem to be brighter. VERY STRONG MAGNET plus a twist lock on the connectors.
Old 11-09-2015, 06:42 PM   #16
Originally Posted by PapaE View Post
Do you still have that dog and/or did you have a nice funeral for it?
You beat me to the question.
ornery is offline   Reply With Quote
Old 11-10-2015, 09:41 AM   #17
Wolverine 1945's Avatar
We had ours get caught under the hitch ball,,, while parking on out property in the forest,,, miles from town,,, burned all the wires,,, I sat for an hour or so and spliced them all back together,,, as a temporary fix... I also found a fuse had gotten fried on the truck,,, went to town the next day and replaced the fuse,,, never did replace the wire !!!
Wolverine 1945 is offline   Reply With Quote
trailer
