Old 03-16-2015, 08:03 AM   #1
Stormrider151's Avatar
Rims
Before I pick up my new trailer I want to put E rated Lt's on my 2012 F150. Will my stock rims be able to handle the E's?Click image for larger version
Name:	ImageUploadedByForest River Forums1426510999.403377.jpg
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 03-16-2015, 08:13 AM   #2
Jim34RL's Avatar
This will depend on the maximum pressure or load rating stamped on the inside of the rim. Do you have P-rated tires on the F150 a lot of 1/2 ton trucks use P-rated tires for a smoother ride than LT tires. Thus the rim will have a lower rating for the tire load than a E rated tire that could support up to 3195 LBS at 70 PSI.
The selling dealer should be able to tell you if your rims are capable of using E-rated tires.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 03-16-2015, 08:25 AM   #3
Crusader 816's Avatar
I have the same rims on my f150 with E-rated tires and not a problem
Crusader 816 is offline   Reply With Quote
Old 03-16-2015, 01:04 PM   #4
Thanks John. That's what I was looking for. Trying to get the wiggle out of the truck when I pull my trailer.
Old 03-16-2015, 01:16 PM   #5
The only "rating" I could ever find about Ford wheels is a max weight rating that seems to coincide exactly with the axle rating- so I'm pretty sure it is a made up number. I know lot's of people are running LRE tires with no problems. I've run LRD tires on mine at 65psi with no problem.
Old 03-16-2015, 03:44 PM   #6
I couldn't find anything stamped on the rims so I figured is ask if anyone else was using e's on rim's like mine.
