Old 09-23-2013, 05:29 PM   #51
Yeah but Joe, you're going to want to buy a bigger truck soon anyway, so you may as well just go ahead and do it now. ;-)
Old 09-23-2013, 06:09 PM   #52
JoeMazz's Avatar
Nope...Tundra suits me just fine.
Thanks all the same......
2015 Jayco Precept 35UP
JoeMazz is offline   Reply With Quote
Old 09-23-2013, 08:34 PM   #53
dcheatwood's Avatar
Originally Posted by JoeMazz View Post
Yep, sure did. Pin weights were higher on the crusaders and I was fighting for every pound I could shave off.
1000 lbs heavier dry wright, 3 feet shorter and 100 lbs+ more on the pin than the rockwood 8282ws. A lot of manufacturers offer one similar to the crusader rst295. Open range light is similar but I don't like the stupid goose neck hitch.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 09-24-2013, 12:53 PM   #54
dcheatwood's Avatar
Hey Joe. New caution. Recently my island turned over in transit during a turn and rode a ways leaning against the stereo facing. Only left scuff marks but could have been worse. Island is very top heavy. Gonna try to rig a secure mount against the lower pantry doors. Will post photos if it works out.
Old 09-24-2013, 01:02 PM   #55
JoeMazz's Avatar
I've been wrapping the wife's bicycle in a comforter with the front tire in between the desk and the island.
Old 09-24-2013, 01:13 PM   #56
JoeMazz's Avatar
Or you could just try and keep all the tires on the ground on turns...
Old 09-24-2013, 01:46 PM   #57
French's Avatar
Joe mazz
As i understand this thread you finally have your new rig with its mis matched ISLAND counter corrected and all is good? yes?? Have you towed it around several hundred miles or more? if so how are hills handled?
Have you weighed your rig fully loaded? If so are you under your max weight?
I can tow 9600lb and load 1850lb max. Your Tundra is likely in that range I would guess.
The Rockwood lite line up has a wide range of pin weights from just over 1000 to almost 1700. I am leaning toward 1200 or so max leaving 600 pounds of stuff. According to GM the max load is calculated after a full tank of gas and 300 lb of people (2) on board.
Like you i am looking to be careful with the weight and not be over -otherwise TV warranty will be void. Thoughts??
MANY THANKS!!
Dave
French is offline   Reply With Quote
Old 09-24-2013, 02:00 PM   #58
JoeMazz's Avatar
Originally Posted by French View Post
Joe mazz
MANY THANKS!!
Dave
RV is actually back at the dealer still trying to iron out the last of the table issues, but I did take it on a short 100 mile, long weekend and it pulled like my old 20ft TT. No hills though.
As I'm sure you've read, with a half ton, it's all about the pin weight. My Tundra has a payload of 1650, but that's one 150lb driver and a full tank of gas. Add hitch in the bed, wife, kid, dog and gear I'm down to 1300 fast. I went on the trip with a stock suspension and full fresh water tank, and it sagged a little so I just added airbags.
I'm happy with the pin weight of my 8282ws, although there are guys with Tundra's on this site that pull the 8289ws and that pin has to be up around 1600-1700 loaded.
Wish I had a 3/4 ton that magically fit in my garage, but I don't, and this set up so far works well.
Old 09-24-2013, 04:28 PM   #59
Ksilvi's Avatar
Actually, the Crusader 295RST is 3" LONGER (31'11") than the Rockwood 8282ws (31'8"). It also comes standard with the Lippert Ground Control self-leveling system, which has been wonderful! Just press the Auto-Level button and walk away!
2017 Cherokee Wolf Pup 17rp
2017 F-150 FX2 Sport
Ksilvi is offline   Reply With Quote
Old 09-24-2013, 07:13 PM   #60
dcheatwood's Avatar
My bad. I pulled up specs from a random online search and got specs for a different unit. I have looked at primetime and liked em.
