Old 07-06-2015, 12:17 PM   #1
Rockwood Sway Problem
We have a 2015 Rockwood UltraLight 2608WS and had it out for the first camping trip of the season this past weekend. We had so much sway that we were really worried about losing control. On the PA turnpike, we could only do about 40 MPH for fear of trucks blowing us right off the highway. We couldn't even get above 50 MPH as it would start to sway on its own.
We are towing with a 2012 Expedition EL with e-rated light truck tires (at full pressure). We have a Reese WDH with the dual cams (dealer installed). I am almost certain the WDH is not installed correctly.
When I spoke to a few other seasoned campers at the campground we were at, they all told me the front of my camper should not be up high than the back of my camper. When we finally got home and I was able to measure on level ground, when fully set up with the WDH on, the front of the camper was 2 inches higher than level and the back end of the camper was about 2 inches lower than the level point (front of camper was 4 inches higher than back).
I have already had the camper back to the dealer once right after we drove the camper home because of the sway but they told me the WDH is within spec. Is it really difficult to follow the manufacturer setup instructions? I just don't trust the dealer enough to go back for a second time to get them to set it up right.
Something just doesn't seem right here.
tntbream is offline   Reply With Quote
Old 07-06-2015, 12:32 PM   #2
Briorick's Avatar
Would suggest you do some internet searching, especially with YouTube. There are some straight forward, easy, and excellent how-to videos on explaining the proper procedure and setups using WDH and fine tuning them. You may find fine tuning them yourself is better than what the dealers would do. I did my own setup using the Videos and am very glad I learned how. As some here have repeatedly stated, they don't trust the dealers with the WDH setups. Check out the Videos, you will be ever so glad you did.
Rick & Brian
1 Happy Camper Pup ( Mya )
2017 Salem Cruise Lite 232RBXL
2004 GMC Sierra 2500HD LT 4x4 6.0 / 4:10
The best plans can be of those that happen in the spur of the moment!
Briorick is offline   Reply With Quote
Old 07-06-2015, 05:51 PM   #3
As already stated, watch the U tube you'll be gald you did. I would say your set up is off. I don't have the dual cam set up, but I understand it's a good system but somewhat hard to get it right. may be some dual cam folks will jump in and help.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 07-06-2015, 06:19 PM   #4
You need to get the TT level or slightly (1/2") nose down. Also you need to make sure your SUV is setup right. The front of the SUV should be a close to it's original unloaded hgt as possible.
Do some research and learn to do your own work on the TT. The WD is really pretty simple once you start adjusting it. If you don't own any tools then it's time to invest in some. You'll save yourself some money as well as frustration when you learn to do your own work.
Most of the time RV dealers just slam the WD on the rig and send us on our way.
Here's a video on the DC Reese. I will say that the Reese DC is harder to get perfect that the rest. simply because you need to get the cams centered on the spring bars.
Reese Strait-Line Weight Distribution System Installation - 2013 Ram 1500 Video | etrailer.com
goduc is offline   Reply With Quote
Old 07-07-2015, 06:59 AM   #5
Thanks everyone. I found the installation instructions also on the Reese website. Doesn't look too difficult. One quick question....when the installation is totally done and trailer is hooked up to the tow vehicle, should the weight distribution arms be parallel to the ground or parallel to the trailer frame?
Old 07-07-2015, 07:24 AM   #6
Ideally yes, but if they are slightly off either up or down really makes no difference if the trailer and tv are level.
Old 07-07-2015, 07:27 AM   #7
Boss Ox & Drovergirl
oxcamper's Avatar
I would suggest paying attention to the difference in height of the front of the TV. If the WDH is installed correctly, the height of the front of the TV (measured from the ground to the bottom of the front wheeel well) should be almost = when hitched and unhitched. Indeed it's better to have the trailer nose down a little rather than nose up.
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 07-07-2015, 07:34 AM   #8
Better to have the trailer level front to back. PERIOD. If not, there is/will be more load on either the front or rear axles. KEEP IT LEVEL. You can tweak it to get it level.
Old 07-07-2015, 07:35 AM   #9
avolnek's Avatar
As mentioned the trailer should be level to slightly nose down to begin with. You also need to make sure if you are loading heavy objects into the camper that the heavier items go to the front to help keep the tongue weight up.
Also, depending on the tongue weight of your camper you may not want to be running full pressure in your tires on the tow vehicle. Max air pressure is for the max load. If you are running max air and not the max load your tires will be balloned out and you'll be riding more on just the center section of your tires and not the whole tread width. It is unlikely this is causing anything with your trailer sway but worth noting...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 07-07-2015, 07:37 AM   #10
I would start with (T/W)! How much T/W # ready to go down the road? How much does the (Unit weight) ready to go down the road? The DEALER cant set up your unit (UNLESS) you have all the (Ready to Go Stuff) in the unit and are at His Dealership? Yes it should be (Level or Down a LITTLE) ! Youroo
youroo is online now   Reply With Quote
rockwood, sway
