Old 07-30-2013, 01:33 PM   #71
thebrakeman's Avatar
My 2 cents:
1. Running without a WDH can hurt. By the last set of numbers, about 300 lbs is removed from the front wheels by attaching the trailer, but not engaging WDH. That weight needs to be replaced.
2. By the latest numbers, engaging the WDH system was restoring all lost weight, plus about an extra 100 lbs. On a 1/2-ton truck, you should be shooting for stock height/weight. Since less WD seems to help your situation, I would back off a bit.
3. By the latest numbers, TW is around 620 lbs. A 1000 lbs system should work just fine with 600 lbs TW. I do not think moving to 800 lbs bars will help you. In fact, my experience running up closer to the limit of the bar(s) actually gave me problems. On rough roads, these 800 lbs bars will flex more than the 1000 lb bars. As that flex unloads, it will push the tongue up harder. Assuming the rough road continues, so will the oscillation. Sounds like more porpoising to me, not less.
thebrakeman is offline   Reply With Quote
Old 07-30-2013, 09:02 PM   #72
BurgPath's Avatar
The manager Camping World stated that they used the 1000# bars for all trailers. "Never had a issue." He said they dont carry the 800# at that store and that they were more $. (Manager speak: YOU will have to pay the difference.)
I laid out everything the Eaz Lift rep and I talked about. Including the fact that the rep worked for CW and knows the Area Rep. He took the Eaz Lift reps info and number and will call him tomorrow to see if they can work out a swap.
For good measure I'll call the guy as well.
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 07-30-2013, 09:03 PM   #73
BurgPath's Avatar
The Eaz Lift rep felt the 1000# werent loading at all. They were too tight and would not be adjustable.
At this point, I'll try anything.
If this fails I'll skip WD and bag the rear of the Titan to level it.
Originally Posted by thebrakeman View Post
My 2 cents:
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 07-30-2013, 09:32 PM   #74
That's what I would do and add two friction sway bars if CW (dealer) won't swap the 1000# bars for 800# ones. I think he's just being hard nosed about it not wanting to admit he's wrong.
Old 07-30-2013, 10:11 PM   #75
BurgPath's Avatar
I'm running 1 anti sway now and still feel a little more then I'd like. Do people actually run 2? Yeah, I'd try it but isnt that like trailer training wheels?
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 07-30-2013, 11:25 PM   #76
Dennis and Julie's Avatar
We run with 2 anti sway, wouldn't go back to 1 for any amount of money.
Dennis and Julie
2018 Wildcat 28SGX
2013 Chevy Silverado 2500HD
2012 Chevy Silverado 2500HD
Dennis and Julie is online now   Reply With Quote
Old 07-31-2013, 07:57 AM   #77
BurgPath's Avatar
You're 30 feet plus. I can see why. I'm only 23.
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 07-31-2013, 08:55 AM   #78
DDC
DDC's Avatar
When I purchased my hensley I was towing a 24ft that would give me white knuckles, of course the hensley cured it.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 07-31-2013, 03:53 PM   #79
BurgPath's Avatar
Haven't heard of those till now. Wow, thats not a cheap item! I can add another anti sway bar for $60!
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
Old 07-31-2013, 04:07 PM   #80
avolnek's Avatar
I highly recommend the air bags in the rear regardless! They are an amazing tool! The inconsistent loads I haul in the bed while camping kept me playing with the w/d on my truck. After installing my bags not only was the truck much easier to level it was SOOO much more stable. Even if the trailer was wagging a little the truck didn't seem to notice it.
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
