Old 07-31-2013, 04:16 PM   #81
hockeytownmom's Avatar
Originally Posted by BurgPath View Post
Trailer drove terrible this morning. When I left work I decided to dump the water tank. Was much better after that.
I empty the hot water tank after every trip at well. We noticed a huge difference in towing when we started doing that.
Kristina & Family
2015 Sunseeker 3170ds
'13 Honda Pilot -Kar Kaddy 3
Nights camped in 2011/36, 2012/9, 2013/24, 2014/27; 2015/50 2016: 34
hockeytownmom is offline   Reply With Quote
Old 07-31-2013, 05:24 PM   #82
avolnek's Avatar
Hard to believe you'd notice a difference... Emptying your water heater will only shave 50lbs off the total weight...
TV- 2015 Ram 2500 CCLB 6.7 Cummins 3.42 gears
Camper - 2015 Saber 322BHTS
avolnek is offline   Reply With Quote
Old 07-31-2013, 05:29 PM   #83
50lbs is a lot of unnecessary weight, imo.
Kristina & Family
Old 07-31-2013, 05:41 PM   #84
X2. 50 lbs would be extremely hard to notice in anything measurable unless it is sitting on your foot.
Old 07-31-2013, 08:07 PM   #85
BurgPath's Avatar
My tank is small, 5 gallons, maybe?
Hopefully CW will call me tomorrow and we can get this squared away. Luckily we dont have trips planned in August but we do in September!
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 07-31-2013, 08:31 PM   #86
If you are referring to the wh tank, they are usually 6 or 10 gal. Depending on the location of wh, if the tank is in the rear, draining the tank would probably add to the tongue weight and not help your problem.
Old 07-31-2013, 08:32 PM   #87
raspivey's Avatar
Originally Posted by thebrakeman View Post
3. By the latest numbers, TW is around 620 lbs. A 1000 lbs system should work just fine with 600 lbs TW. I do not think moving to 800 lbs bars will help you. In fact, my experience running up closer to the limit of the bar(s) actually gave me problems.
I agree...and disagree. A 1000 lb. bar is rated for a MAX of 1000 lbs. Most bars I've seen have a weight range of about 200 - 400 lbs. That would mean his 1000 lb. bars could be rated at anywhere from 600-1000 or 800-1000 lbs. Even at 600 lbs. at the bottom end, he's most likely at the very bottom of the weight range and, like you said..running closer to the limit could give you problems. A set with a range of between 400 - 800 would be ideal for that setup.
Old 07-31-2013, 08:44 PM   #88
With his tongue at 640#, the 1000# bars are excellent at transferring weight to the front of the truck, but do not flex any on rough roads and therefore transfer all the bouncing to the truck. He needs the lighter bars to allow the bars to absorb some of the bounce. I would imagine he could get by with 600# bars and have a much better ride. 600# bars pulled up about half way would transfer wt to the front of the truck and still absorb the trailer bounce being transferred to the tongue.
Old 07-31-2013, 08:56 PM   #89
raspivey's Avatar
Might be just a little too heavy for 600's. It'd ride better, but they probably won't be stiff enough to transfer enough weight.
Old 08-01-2013, 06:09 AM   #90
BurgPath's Avatar
According to the rep tech from Eaz Lift the bars are rated for more then labeled. As I recall he said around 15%. So the 800 should be correct.
He also asked about the behavior of the bar when I synch them up. I stated it was easy to get on the 5th link, almost didnt need the bar. He stated that was wrong, I should have to put some effort into getting the chain locked in.
Once i have the bars he will help me get them correctly set.
Kevin (BurgPath)
2017 Ford F350 CCSB
Mods and Pics
