Old 06-12-2016, 07:03 PM   #1
Rotate WDH tension bars?
I have a Equalizer Hitch rated for 1000/10,000. My tongue weight is only 500-600 lbs, well below max. However I'm wondering if the tension bars should be rotated left to right or top to bottom to help avoid their "taking a set" or bending. They are showing no signs of problems, I'm just curious.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
CedarCreekWoody is offline   Reply With Quote
Old 06-13-2016, 03:33 PM   #2
I'm not familiar with Equalizer, aside from seeing them, however I don't think there are different stresses placed on them depending on the side.
325BH is offline   Reply With Quote
Old 06-13-2016, 04:25 PM   #3
Just run them with the stickers on the bars facing outward.
Big Red and 30WR is offline   Reply With Quote
Old 06-14-2016, 09:15 AM   #4
I had an Equal-I-zer for 10 years until we got the 5er and I never thought about that. I didn't keep track of which side the bars went in so I probably 'rotated' them at least a few times.
I don't think it would make much of a difference whether you did or not.
Gotta go campin!
Old 06-14-2016, 01:21 PM   #5
Thanks. I suspect you are correct, just wanted to confirm.
Andersen hitch
Old 06-14-2016, 01:31 PM   #6
MarkyB's Avatar
My Centerline TS, (basically a copy of the Equalizer,) says to install the bar with the info stamp up.
No distinction between left and right.
16 F-250 Lariat 6.2 -- 16 Wildwood 31KQBTS
Nights Camped in 2016 : 25
Nights Camped in 2017 : 20
MarkyB is offline   Reply With Quote
Old 06-14-2016, 01:48 PM   #7
DW's 401(k) Plan
DaGrinch's Avatar
Used the same bars (1,000/10,000) as you on my Equalizer when I had the trailers. Never rotated them and never had any problems in the 8 years we used them. Touched up the paint a few times, but that was it. They now have a home with another FRF member out in Idaho.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
