05-21-2013, 09:05 AM
RPM's
Do any of you pay attention to the RPM's your tow vehicle is running when in normal towing mode? Just curious.
05-21-2013, 09:11 AM
Yes - being a truck driver one learns to drive by the tack - now retired but still drive by the tack.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
05-21-2013, 09:12 AM
Very attentive to the rpms. Especially going up and down mountains. Same RPM and gear going down as it took to get up.
05-21-2013, 11:21 AM
Yes, RPM's very important criteria!
Of all the things I've lost in my life the thing I miss the most is my mind!
05-21-2013, 11:29 AM
Absolutly. I am running close to max so I always switch over to the RPM display when I tow. No need to run higher than I need to.
05-21-2013, 11:30 AM
You bet, limit mine to 3,600 rpm max. If that's not fast enough for those behind me, they can use the left lane or just be patient. Even tho' it will go a lot higher, I just choose not too rev it any higher in drive while towing.
05-21-2013, 11:49 AM
I guess I'm different here, but since my TV and passenger car are both automatics I rarely look at the tach in either one.
I do look at the TV one when we are going up a grade just to see what it it, but that is about the only time.
I have often wondered why auto manufacturers even bother to equip standard cars and small trucks with them other than to fill up dash board space.
I wonder if the majority of vehicle owners even are aware of what they are or what purpose they serve.
05-21-2013, 11:51 AM
If you know your TV's torque curve, you can up/downshift to maximize torque at any time - particularly helpful when climbing hills, etc., reduced strain on engine, and decrease in speed while climbing. This apparently helps maximize fuel mileage, also. Of course, if you're driving an automatic, you may not have a lot of control over shift points. Our MH is on Mercedes chassis, and the transmission has tip-shift feature, which is very helpful controlling shift points.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
05-21-2013, 11:54 AM
All of my vehicles have had either factory tachs (since 81) or I added them on the ones before 81 and all were automatics. I just like to know what the engine is turning plus it will give you an indication if the tranny is starting to slip.
05-21-2013, 12:12 PM
I don't pay much attention to the tachometer most of the time. My truck just chugs away at 1,600 RPM 98% of the time. I get an occasional downshift and then maybe 1,900 RPM. But I just set the cruise and let the truck manage itself.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
05-21-2013, 01:44 PM
Wanna Be Camper
Not really, other than for entertainment. I put the truck in T/H cruise on at 100kph and let the puter do it's job. If the engine hits 5k so be it, it was designed to do it and the computer won't let it hurt itself at least Ford's won't as they will reduce power if they detect any abnormality be it bad gas, temp going up too quick etc.
John & Deb
2011 Flagstaff V-Lite 30WRLS
05-21-2013, 01:56 PM
Me too. When I am at cruise speeds less then 60 MPH (using the Tow/Haul mode to get there) the RPM is about 1800 RPM. Taking it out of Tow/Haul will upshift to OD and the RPMs drop to about 1600 and I re-engage the Tow/Haul.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-21-2013, 02:10 PM
Looks like the unofficial results lean toward not using the tach when towing our RV's.
05-21-2013, 02:14 PM
Resident Masshole
I look at mine all the time. I also view the real-time MPG info. Neither one seems to impact the way I drive though lol
05-21-2013, 03:12 PM
Just curious. We've got a new truck and travel trailer. My first haul last Sunday, I kept the speed around 65 mph which put me at 2500 rpm. However, we were bucking a pretty strong headwind most of the trip.
The truck is an automatic and I seldom let it shift down into a lower gear. Most of the times, I can get a good enough run at a hill that I don't need the extra gear.
05-21-2013, 03:33 PM
I watch the RPM's mostly just to see how hard the suburban is working.
I always use the tow/haul mode.
I try to keep it from shifting down unless I really need to or can't get a run at a hill because someone is in front of me.
We don't have much of what most people probably call hills here but there are elevation changes. I didn't use cruise to keep it from kicking down a gear going up the hills.
Do most use cruise? Just on the flat land?
22 Forest River RPod 192
2019 Nissan Titan
05-21-2013, 03:52 PM
I seldom use the cruise. Just feel a little more in control without it plus I don't like it kicking in to a lower gear when I don't want it to.
05-21-2013, 06:04 PM
My 2013 Chevy Silverado 1500 shifts like crazy and I'm only pulling a Rockwood Mini Lite 2503S. It's ridiculous when I'm heading into a strong headwind. With a tailwind, it's not too bad.
05-21-2013, 06:29 PM
I pay more attention to my turbo boost than my RPM's.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
05-21-2013, 06:30 PM
Ooooohhhh turbo boost...........
Argh argh argh!
