Old 02-17-2013, 02:05 PM   #11
Sometimes an intermittant problem such as this is caused by the blades in the RV plug or the connections on the truck receptacle become loose or spread apart. There are several versions of the plugs. Connect the trailer to the truck and have someone watch the lights as you move the plug around in the receptacle. If you are getting intermittant lights, take a small screwdriver and adjust the plug and/or receptacle contacts so they make better cotact with each other.
2012 Sabre 250RLUD
2011 GMC 1500 Sierra
Max Tow, 6.2, 3.73
Rod, Debbe 1 spoiled Chihuahua and Becky the cat
1Texan is offline   Reply With Quote
Old 02-18-2013, 10:01 AM   #12
daydreaming about camping
jeeplj8's Avatar
I would guess that when you sprayed the rusted socket you shorted that one. Re-check all your fuses.
And if it was that rusted, it may have failed internally. Time to get out the volt meter and see what is what.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
jeeplj8 is offline   Reply With Quote
