Old 02-16-2013, 08:58 PM   #1
Jim
RV towing light issue
I have recently acquired a 2003 Ram 2500 to tow a 26rl flagstaff. Hooked up this afternoon, checked lights. Running lights and left signal and brake light working, right signal and brake light not working. Checked and found bulb rusted in receptical. Purchased new bulb and cleaned recepticle with emery cloth. Afterwards had no lights at all on the RV. Unplugged cable from truck, checked fuses in truck. Plugged cable back in to truck and now have running lights, but no turn signals or brake lights. Dark by now so don't know if my trailer brakes work or not. Any suggestions.
JimP is offline   Reply With Quote
Old 02-16-2013, 09:04 PM   #2
jevanb's Avatar
hit the manual slide on the controller and listen for the buzz of the brake magnets. or try to pull with the slider slid to brake and if the trailer no move the brakes are working
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 02-16-2013, 09:14 PM   #3
Jim
Thanks for the quick response, will check that first thing in the morning, then tackle the light issue again.
Old 02-16-2013, 09:20 PM   #4
Typically electrical issues like that are related to a bad or poor ground wire. Check and clean grounds.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 02-16-2013, 09:42 PM   #5
puff's Avatar
What pwrstroke said..!
Check you ground on the truck and on the trailer, I am betting one is dirty or rusty. Invest in a small tube dielectric grease it will save you lots of tylenol on the headaches.
If that does not work check every light bulb, socket, grease and re-install. Some manufactures run their grounds through a light or that connection and if the ground fails there it affects the rest in the line...just like those awful christmas lights.
Glen & Robyn (A.K.A. Puff & Crickit) Full Timers..
2006 F350 6.0 with 3.73 gears, 4X4, Extra-Cab Long Box, Oil/Tranny/P.S. Coolers. Coolant filter. SCT Livewire.
2011 Cedar Creek 36RE, Auto levelers + too much to list..!
puff is offline   Reply With Quote
Old 02-17-2013, 07:49 AM   #6
Jim
Thanks for responding. The bulb on trailer right rear was rusted. But it would light with the running lights. Left rear was working ok. When I removed the bulb on the right, it broke and I sprayed some oil on to loosen the rust, maybe that started the rest of the problem. Used emery cloth to remove rust. After replacing the bulb, nothing worked on the trailer. Unplugged, Checked fuses, re plugged. The running lights were now working, but no brake or signal on either side of trailer. Will definitely get some dielectric grease as soon as stores open today.
Old 02-17-2013, 08:24 AM   #7
Dave_Monica's Avatar
Have you tried spraying some WD40 into both the & pin socket and camper connector to eliminate any moisture from causing the problem?
Dave
Old 02-17-2013, 08:32 AM   #8
puff's Avatar
If the bulb socket was that rusted you may have to pull the light base of your unit and check the wires in the back or if you see the wires coming into the socket look at them. Make sure they too are not rusted or broken. Make sure you check those grounds first, I bet the problem is there. Hope this helps, good luck.
Old 02-17-2013, 09:00 AM   #9
Trailer Trash
A spray can of ether starting fluid works good for cleaning up crud, green corrosion, etc. in trailer plug fittings. It's under good pressure so it blows stuff out of tight spots. Dries very quick too. This is a quick fix for on the road to get lights gong again. Replace items when you get home or clean them for real.
Get one of these to check trailer harnes from truck - confirms truck plug is ok. If truck plug is ok, then you know you have a trailer issue. Plug one end in for 7 pin round. Use other end to check 4 pin flat.
Ultra-Tow 7- and 4-Way Circuit Tester, Model# DBP7+4 | Wiring Kits| Northern Tool + Equipment
joelek is offline   Reply With Quote
Old 02-17-2013, 09:10 AM   #10
puff's Avatar
Now that is cool tool to have...it however will not show intermittent connections unless you have a helper move wires while you watch the lights but still a cool tool for the tool box.
