Old 07-18-2015, 11:00 AM   #1
Safe to have slight play in fifth wheel jaws
Hi everyone, recently I bought a Curt fifth wheel hitch and I've noticed a little bit of play within the locking jaws of the kingpin. Just did a test of it this morning in a large parking lot, and saw that when I applied brakes, I could see the trailers skid plate move forward just slightly, but enough to feel it. When I let the brakes off, it moved back slightly. But the jaws are still locked. Is it normal to have this little wiggle room?
Jared and Krista
2016 Sandpiper 371 REBH
2011 Ford F-250 SuperCab XL 6.7L TD, Curt 20K
Jsabe07 is offline   Reply With Quote
Old 07-18-2015, 11:04 AM   #2
I would fabricate metal shims or tighten something and get rid of all play. I had to shim all 4 legs on my Reese hitch to get rid of the movement.
If there is movement now, it will only get worse as time goes on due to the constant movement/banging.
Old 07-18-2015, 11:59 AM   #3
clr
Some slight play in the jaws to the king pin is normal IMO, all of my hitches have had some play there. If you are concerned I would go ahead and talk to Curt support folks I am sure that they can tell you how much play is too much.
clr is offline   Reply With Quote
Old 07-20-2015, 02:19 PM   #4
I have the Q16 right now, and my trailer grosses at 15,500. Should I upgrade to a 20K?
Jared and Krista
Old 07-20-2015, 03:31 PM   #5
iceblaze580's Avatar
I would 15,500 is almost pushing that Q16 to its limits
iceblaze580 is offline   Reply With Quote
fifth wheel, light, wheel
