Old 04-05-2012, 11:47 AM   #1
Safe towing?
My TV is a 2009 F150 4x4 Supercab XLT
Wheelbase 145"
4.6 3v EFI V8 6-SPD
3.55 Ratio Reg Axle Trailer Tow package
Looking at Rockwood Ultra Lite 27033ss
Length 31'11"
Hitch weight 594 lbs
Dry weight 6,048 lbs
Gross weight 7,474 lbs
Bandit7 is offline   Reply With Quote
Old 04-05-2012, 11:49 AM   #2
Triguy's Avatar
Could you also list the towing cap and payload for your Ford?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-05-2012, 12:01 PM   #3
I believe payload is 1550 & tow cap is 7900
Old 04-05-2012, 12:12 PM   #4
Herk7769's Avatar
http://www.trailerlife.com/wp-conten...Guide-2009.pdf
2009 Ford F150 Specifications
F-150 SuperCab Std. Bed 4WD 4.6L V-8 3V 7,900 (a6,d)
F-150 SuperCab Std. Bed 4WD 4.6L V-8 3V 9,400 (a6,e)
a6 = Auto Transmission, six speed
b = 3.15:1 axle ratio
c = 3.31:1 axle ratio
d = 3.55:1 axle ratio
e = 3.73:1 axle ratio
Payload is 1460 based on the driver and a full tank of gas only.
GVWR on the truck is 6950
Watch your tongue weight.
Looks like you have the towing capacity for that camper (watch the max weight because you are at the limit) also be careful of your GVWR and combined weight limits on the truck when loaded for camping.
HAM CALLSIGN - KC3FFW
Old 04-05-2012, 12:12 PM   #5
Dave_Monica's Avatar
Here's the link for Ford Fleet Towing
https://www.fleet.ford.com/showroom/...9RVTTguide.pdf
On pg 17, your truck is rated for 7900 lb max towing and 13500 GCWR. The Rockwood fully loaded will put you close to the max. If there's only two of you and you don't load heavy, you should be OK.
Dave
Old 04-05-2012, 12:26 PM   #6
I thought it would be close but it's just 2 adults & 2 yorkies
I had one dealer try to sell me a 34'Outback 298 RE
Dry weight 7,400
Old 04-05-2012, 12:59 PM   #7
Herk7769's Avatar
Dry weight 7,400
Yowsa, we hear it all the time here.
Old 04-05-2012, 01:33 PM   #8
I just tow the TT for DW!
kamp k's Avatar
Dry weight 7,400
Typical. As others have mentioned, you should be ok, if you pack carefully and watch your all of your meaningful weights. Good luck.
2008 Ford F350 King Ranch Lariat SD CC 4x4 V10 4:10
2012 Rockwood Windjammer 3008 - Equalizer 12k
2007 EZGO TXT Lifted/Custom Golf Cart
Nights Camped: 2011(52) 2012(65) 2013(65) 2014 (51) 2015 (40)
kamp k is offline   Reply With Quote
Old 04-05-2012, 01:36 PM   #9
Triguy's Avatar
Bandit,
I agree with those guys. You're good.
The only thing to watch for is carrying too much in the bed of the truck. As an example, your trailer if reasonably loaded would be around 7,000lbs which would give you a tongue weight of 900-1,000lbs. This leaves you with a net payload for passengers and other cargo of 460-560lbs.
You should be fine (unless you plan on hauling hundreds of extra pounds in the truck bed when you are camping).
You were right to run away from that Outback dealer. Salesmen can be crazy... and not in a good way.
Scott
2012 Shamrock 233S
Old 04-05-2012, 02:20 PM   #10
Thanks everyone
