Old 04-30-2016, 09:09 PM   #21
Oaklevel's Avatar
Originally Posted by trbomax View Post
OK!
Sorry not meaning to come across too strong, I enforced safety from 1980 to 1991 for Newport News Shipbuilding including cranes from 7 ton to the 900 ton crane and am still enforcing safety including cranes in the Commonwealth of Virginia.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-01-2016, 08:18 AM   #22
keeprr's Avatar
Thanks for the input.
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 05-01-2016, 08:52 AM   #23
Back to the OP's question, I had the same issue when I just upgraded to 2500HD. The hooks will fit in the front holes on either side of the receiver if the spring clip is removed.
Also to the person that heated the hooks to spread them out, not sure but you may have changed the load rating on the hooks by heating them.
2016 Chevy Silverado 2500HD Duramax LTZ Z71 Extended Cab, Long bed
2012 Dodge Ram 1500 5.7L Hemi
(with K&N Air Intake) (traded)
2012 Rockwood 2109S (Sold)
2014 Cougar X-Lite 21RBS
wbdvt is offline   Reply With Quote
Old 05-01-2016, 09:53 PM   #24
Oaklevel's Avatar
True the load rating would be changed, but the load rating of the hook is not for pulling strength it is based for lifting capacity. And not at all for a shock load. (Trailer breaking away). Pulling a 10,000 lb load and lifting a 10,000 lb load are not the same.
1966 Mustang GT
1986 Mustang SVO
Old 05-01-2016, 10:01 PM   #25
flymhi's Avatar
No need to remove the spring clips. We picked up our new TT a couple of weeks ago and I had the same issue. I took a pipe and opened the hooks just a little. Now they go on and the spring clips work the same.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
safety
