Old 04-29-2016, 09:17 PM   #1
keeprr's Avatar
Safety Chains
I upgraded to a GMC 2500 which now has the 2 1/2 " hitch receiver. The hooks on the safety chain on the Mini Lite do not fit in the hole on the receiver. Those of you that have this new hitch receiver, how are you connecting your safety chains?
2016 Open Range Light 297RLS Fifth Wheel
2015 GMC 2500HD 6.6L Duramax
Days Camped. 2015: 17
Days Camped 2016: 58
keeprr is offline   Reply With Quote
Old 04-29-2016, 09:21 PM   #2
rsdata's Avatar
would something like this help?
Safety Chain Quick Link, 1/2"10K Hidden Hitch Accessories and Parts 49135
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
rsdata is online now   Reply With Quote
Old 04-29-2016, 09:22 PM   #3
Who Dares, Wins
doc73's Avatar
I put larger hooks on. I never did this... But did you try the holes right by the spare? Someone said they tried this and it worked with stock hooks.. I needed longer chains still so not the end of the world. I used larger snap hooks on the rear most holes.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon-EOW 11/22/2017
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-29-2016, 09:23 PM   #4
Kenny kustom's Avatar
Larger hooks here too!
20 bucks for the pair, 3 mins to change.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 04-29-2016, 09:39 PM   #5
Capt. Mike's Avatar
I put quick links like those in post 2 in holes on my 2015 2500HD hitch, then hooked the original snap hooks of the safety chains onto the quick links. It takes two links per side, though, because by the time you go through the hitch "hole" you still don't ave room for the snap hook, but you do have room for a second quick link. the safety chain hooks into quick link #2.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-29-2016, 09:48 PM   #6
trbomax's Avatar
Quick links are not dot approved for that application.It probably doesnt matter on a camper, unless you have to scale and get hit with an inspection.Then you will pay a heftey fine and wont move untill they are changed.I know 2 people that barrel race horses and have thir name on the truck/trailer,which makes them*commercial and requires a dot number.One got busted in Iowa, the other in Nebraska.
edit) an anchor shackel IS dot approved.
trbomax is offline   Reply With Quote
Old 04-29-2016, 09:57 PM   #7
Quick links will not work as they will not open wide enough to fit the hitch. I fabricated a 1/4" plate that bolts to the under side of the hitch and it turns back a couple inches. Bolted on with 2- 7/16" grade 8 bolts.
USAF Ret. ______________________________________
2015 24 FQSL NITRO TH
2015 2500 Silverado Crew Cab LTZ Duramax 4X4
2012 HD Street Glide
2008 Honda FSC600 Silver wing
hdmtnrider is offline   Reply With Quote
Old 04-29-2016, 11:14 PM   #8
I am having the same issue. I posted my problem in the towing sub section here a few weeks ago. There were some good suggestions but I haven't settled on my own solution yet. If you do please post it.
2017 Keystone Cougar 28RDB
Buck1032 is offline   Reply With Quote
Old 04-30-2016, 08:19 AM   #9
DDC
DDC's Avatar
I just opened up the hook a bit with a little heat did not take much it's a very poor design though.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-30-2016, 09:23 AM   #10
Same problem here, I've been using the side holes of the hitch instead but it's not the best solution. I'm going to buy bigger hooks and change them, I don't trust those little quick link things. I stopped at a truck store and tried a huge d ring, it fit through the hitch hole, but it wouldn't allow the camper hook to close either.
2014 Chevy 2500 CC, Duramax
2017 Wolf Pack 25pack12 Toyhauler
polishdon is offline   Reply With Quote
safety
