Old 06-04-2016, 03:16 PM   #1
Scale help
Ok, I KNOW there are smarter people out there than me. I'm hoping someone can help me determine if my set-up is good or not. Went to the scales this morning, here are the tickets:
In case you can't read my writing... All are with a full fuel tank, trailer loaded as if headed on the road, a few things in the bed of the truck, but only me, not the family in the truck.
#1 is with no weight distribution bars hooked up (But I put them in the bed of the truck, if that matters)
#2 is with the bars hooked up, on the 7th chain link
#3 is obviously with no trailer but the truck still loaded up and the bars in the bed.
Please help me determine if I am set up right.
Ok, if it matters, it's a 2006 F150 4x4 supercrew, short bed, 3.73 rear, 5.4L engine.
Also, how can I calculate the tongue weight, or do I need a different measurement?
Thanks folks!
Joe
2014 Salem Cruise Lite 261BHXL
2016 Chevrolet Silverado 1500
joehbus is offline   Reply With Quote
Old 06-04-2016, 03:22 PM   #2
Thought I attached the pictures, oops.
ID:	110134   Click image for larger version
ID:	110135   Click image for larger version
Old 06-04-2016, 03:47 PM   #3
Broadway Joe's Avatar
If I calculated correct your tongue weight is 734 lbs, your only shy 80 pounds on the front with w/d, looks good to me.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 06-04-2016, 04:44 PM   #4
Thanks! How did you come up with that? What do you mean by 80 pounds shy?
Sent from my SM-G920V using Tapatalk
Old 06-04-2016, 07:29 PM   #5
Your front tire empty weight was 3440 with trailer and w/d is 3360 gives you difference of 80 lbs. You have recovered all but 80 pounds with the trailer and w/d hooked up.
Without w/d you lost 220 lbs
Joe
Old 06-04-2016, 07:29 PM   #6
Ah! Thanks again!
Old 06-04-2016, 07:40 PM   #7
You can use this worksheet to check your axles weights. I would check it so you know for sure.
http://fifthwheelst.com/conventional...alculator.html
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
uhduh camping is offline   Reply With Quote
Old 06-04-2016, 08:55 PM   #8
Scale help
The tongue weight is 520 lbs. You take the total truck weight without WDH from ticket 1 and subtract the truck weight from ticket 3. Your trailer weight is 4900 which is the gross weight from ticket 1 minus ticket 3. You tongue weight percentage is 10.6. Your set up looks good, but a little higher tongue weight would make it better.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-04-2016, 09:22 PM   #9
raspivey's Avatar
Fat fingered the calculator there . 740 TW (15.1%)
EDIT: Actually, I see what happened. You have to use rear axle without WD, not with for actual TW. Now...which method is better for real world scenarios while using WDH I'm not sure.
Old 06-04-2016, 09:23 PM   #10
I got the 520 number, how are you coming up with 740?
