04-08-2011, 06:51 AM
#51
If you are going to sell it, I call dibs on it  They can be daisy chained obviously and another one won't hurt
Originally Posted by flyrotor
No I haven't taken the time to set it up for the Dodge, I plugged it in one day and I wasn't getting the horse power or torque readings so I took it out, it's just sitting on the shelf in the garage. My Dodge has the 6 speed manual transmission and I don't believe it will monitor the temp there as well.
The Dodge has a pretty good reading on fuel consumption and MPG's, when it was in the suburban the things I regularily monitored were MPG, Miles to empty, Trans Fluid Temp, HP, CTQ.
I might play around with it a bit more, not real sure, I also am not looking forward to mounting it anywhere in the Dodge.
My 2001 BWM keeps setting of the check engine light, so I might use it more for checking codes to see if I really need to get in the shop or not.
2006 Ford F-150 XLT/XTR 4.6l, CrewCab. short bed
2011 Surveyor SV-291
04-08-2011, 07:09 AM
#52
Moderator
Originally Posted by mtnguy
I have been using my MPG in place of the LOD.....when that puppy starts showing 8 mpg or less, the truck is ready to shift down. I will now start monitoring the LOD instead.
I did that for a long time too. It does work somewhat as an analog to LOD. And it works reasonably well if you do want to monitor your MPG while towing.
2012 F150 FX4 Ecoboost, 2008 Surveyor 235RKS
2003 Yamaha FJR1300, Reese Dual Cam WD
1969 John Deere 1020, 1940 Ford 9N
Jonsered 535, Can of WD-40, Hostess Cupcakes
04-09-2011, 06:38 AM
#53
I got my ScanGuage II in the other day. Plugged it in and was working. I started working on the XGuages for tranny temp, etc... nothing. No matter how I tried them (with 01 or without, PVM or CANSF). I even tried codes for things I didn't want. I was dissappointed to say the least. Then the geek in me got the better part of me, I'll write my own codes.... I'm not a programmer! LOL. After a while I just gave up, reset the ScanGuageII to "DEFAULT SETTINGS" and "BAM" all my factory XGuages that I wanted were working! It is very obvious to me that the SGII will pay for itself in a very short time! Can't wait to tow... observing normal driving readings to get a base line. GREAT TOOL!
Kirk, KN1B
2011 Flagstaff 26RLS
2000 GMC Sierra 1500
04-09-2011, 06:41 AM
#54
Moderator
Kirk, glad you got it working. After you reset your gas mileage during the 1st couple of gas stops, you will be good to go.
Chap & DW Joy in Ruckersville, VA.
2006 Ford F150 Super Cab 4x4
2008 Surveyor 263
04-09-2011, 06:55 AM
#55
Thanks Chap,
I will have to wait for my next trip with the TT. I drive a company vehicle during the week and only use the TV around town on the weekends. The town isn't big enough to burn that much gas without getting dizzy  .
My main concern was transmission temp. I had the transmission rebuilt after a code, transmission component slip, was read on our way to FL at Thanksgiving. We made it home OK, and had the transmission rebuilt prior to any serious damage. I do not want to damage anything more, that's for sure. BTW, the TV had a 128,000 when I bought it, didn't plan on a TT at that time. I had an aftermarket analog guage installed. The analog guage is not the same as the SGII readings. The higher the TFT the more difference appears (SGII being up to 30* higher than the analog guage). The analog guage sensor is in the pan, and still trying to find out where the computer gets it's reading from (sure it's inside the transmission). A friend of mine is the service manager at the local GM dealer and can be a wealth of info, but he is not sure about where the TFT sensor is.
Oh well, hopefully I'll have to go somewhere today and get to play some more.... tough part is keeping my eyes on the road and not all the data spewing out infront of me!!
Kirk, KN1B
04-10-2011, 04:24 PM
#56
Moderator
That was the funniest line I've seen in awhile!!
04-19-2011, 03:48 PM
#57
Moderator
Originally Posted by lbrjet
I BAR works on my truck, but haven't had a need for it yet.
Hmmm, BAR might just work on newer trucks. Like Bob, mine just comes up blank. Can't say I didn't try.
2008 Surveyor 263
05-13-2011, 08:23 AM
#58
I'm up and running!
LOD came up automatically as a standard gage, as well as the other standards. I also have TFT and GR as Xgauges using the website codes.
FYI,
SLP would not work for me, with either of the website codes. I posted a question on ExplorerForums for the 4th gen (6-speed) version. Well, James from Linear Logic found my hit, did some digging, registered for the forum, and provided me with an "experimental" set of codes to try.
So, if SLP isn't working for you, try the codes below. Note that instead of providing % convertor lock (fully locked being 100), these codes provide the difference in convertor input/output speeds (input minus output). So a locked convertor yields an SLP reading of "0". Slippage will be a positive number, and can be quite high.
This will work on Explorer/Mountaineer with V8 and 6-speed transmission, and I bet it will be needed on F150s with the 6-speed, too.
Torque Converter Slip (RPM)
TXD: 07E12211B8
RXF: 0462051106B8
RXD: 3010
MTH: 000100100000
NAM: SLP
2004 Surveyor SV261T UltraLite Hybrid
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 617 |
| 137 members and 480 guests |
| 0721SSROO, 1l243, 4bnabird, 4kmprs, Army-dude, autorot8, B47, backpacker3, bdn56, Bigmatt, BlakeB, bob213, bob34787, BOBFIDY, Bobhaus, bojack, Brendan, buccello, camperman62, campfun, caper, capucine, Cards1989, Cascade Bob, cat1956, Cincy6, ColoradoGreg, Cowracer, crazycampers, DAISY BOYKIN, dashonthedash, dasimser, Dave_Monica, davidjb, ddemme, deerslayer, depo, DGrissom, dirtman7, djorgensen3, dunnnc, Ed D, elind, Falcon35, feerobk, Filthy Beast, Fire Instructor, fivecodys, FreedomTracker, fz_sledhead, GarthJ, GaryRudolph, GeneOB, GinaBruce, gredmer, grhodes50, Happy Campers 79, hark582, hokiecampers, hotrodj125, Iggy, Itsthetwoofus, J R, JAJ73, jes520, jrlehr, KarenS144, kick, kirk37r, kixonrt66, KKapa, ktkoch, KyDan, Laura, lazyb1626, LFugate, lmcleister, lochsa, LuckyMcBRIDE, Mad4sax, mamentt, mark250, Mpwelch50, mraynie, mrores, mrscot, mtnguy, myredracer, NanaKaren, Notuck, nuisance, Old car, Old Jeeper, oldiescc, onthelake, padave65, pappcam, Paul H. Eustace, Pharmofish, pick, PrairieBoy, rawlus, ResQMoore, RGH, RickV, RJHuser, rockin'ray, ronhanson, rotorhead1250, rstoro, Rupert Rick, rweier, sail2liv, SDENN4281, sledhead77, softwarejoe, Taranwanderer, Timex, Titleguy, Tjah, tmmar, tojo70, travyp, treadwelll, Triguy, trudinator, T_LMurphy, unhcharger25, UPGRADER, venturetaz, VinceU, vlite2011, wagon52, Waterfowlwarrior, wayward1, Westernflyer, yworrydog |
| Most users ever online was 996, Yesterday at 11:04 AM. |
