Old 11-24-2013, 12:51 PM   #31
N3HCP's Avatar
Originally Posted by Chewie View Post
Those filters look pretty cool. I hope ford or any manufacturer wouldn't void a warranty for filtering above and beyond the oem. But I'm sure they would try.
I think a lot of it comes down to the dealer. It's common knowledge they make far more money on out of warranty work. If the dealer tells Ford the filter caused the problem Ford will likely agree. I know and trust my dealer, what I worry about is the dealer I might have to work with in the even of a failure far from home. I may get a honest, trustworthy one or a complete crook.
2013 F-350 Diesel Dually, 6.7L with 3.73 rear with 50 gallon Transfer Flow aux fuel tank, ScanGauge II, Tire Minder on all 10 tires, 2M ham radio, and the ever popular CB.
2014 Surveyor SVF-293RLTS
2014 Clipper 16FB
N3HCP is offline   Reply With Quote
Old 11-24-2013, 07:16 PM   #32
6.7 Scorpion
Just hit 7500 miles and performed second oil change. No problems or complaints so far. My mpg has been interesting. The highest I've seen has been an unloaded 18.2 highway @ 62mph. It drops like a rock if I exceed 70mph. The lowest has been 11.8 towing the fiver loaded to 11.5klbs @ 65mph. Again,it drops like a rock if I exceed 70mph. The average at 7500 miles is 14.6. The sweet spot does seem to be 60-62mph. All these numbers are as per the trip computer but I have hand calculated as well and the computer is actually pretty accurate.
All this said, you really have to need the horsepower and torque to justify the extra dough you will spend on the cost of fuel and maintenance on these beasts over a gas rig. Everytime I hitch up to the fiver the truck reminds me why I traded my 2011 F-250 6.2 for the 2012 F-350 6.7. In my mind, there really is no comparison. The 6.2 is a really great power plant but just did not give me what I felt I needed in a a tow vehicle.
Best to all this Thanksgiving!
Name:	F350 & Puma.jpg
Ricky, DW Terry, 11 Kids and Grandkids who all want to go camping with me! Life is good!!
2012 F-350 SuperDuty 6.7 SRW CC, Reese Elite 30144, 2013 Puma 351THSS, 2009 EZGO TXR, 2005 Palm Beach 211 Bay, 2004 HD FatBoy.
rabraz is offline   Reply With Quote
Old 11-24-2013, 07:36 PM   #33
turnerpa's Avatar
Originally Posted by rabraz View Post
Just hit 7500 miles and performed second oil change. No problems or complaints so far. My mpg has been interesting. The highest I've seen has been an unloaded 18.2 highway @ 62mph. It drops like a rock if I exceed 70mph. The lowest has been 11.8 towing the fiver loaded to 11.5klbs @ 65mph. Again,it drops like a rock if I exceed 70mph. The average at 7500 miles is 14.6. The sweet spot does seem to be 60-62mph. All these numbers are as per the trip computer but I have hand calculated as well and the computer is actually pretty accurate. All this said, you really have to need the horsepower and torque to justify the extra dough you will spend on the cost of fuel and maintenance on these beasts over a gas rig. Everytime I hitch up to the fiver the truck reminds me why I traded my 2011 F-250 6.2 for the 2012 F-350 6.7. In my mind, there really is no comparison. The 6.2 is a really great power plant but just did not give me what I felt I needed in a a tow vehicle. Best to all this Thanksgiving!
Nice rig!!! I will post pictures of mine hooked up to some of my work equipment when I get it to texas and hooked to something!!
turnerpa is offline   Reply With Quote
Old 12-30-2013, 06:29 PM   #34
BrianSF-GA's Avatar
Originally Posted by schrederman View Post
I have been researching this because I am planning to buy a 2014 F-250... maybe... However, I am hearing / reading about fuel pump failures with these engines / trucks not being covered under warranty, and costing the owners $10 - $15K. I am also hearing that GM and Dodge are using the same Bosch pumps, with similar results. Apparently when the pump fails it blows small bits of aluminum throughout the fuel system and it all has to be replaced, right down to the injectors. This is because the EPA demands that we use low sulpher fuel that contains less lubricating qualities than European diesel fuel. I read that Dodge has a class action suit against them for not honoring warranty issues of this nature, but that GM is honoring their warranty. Is anyone else getting any of this info? Can anyone shed a bit more light on it?
A couple of quick comments to your post ...
Spend some time in a Power Stroke forum and read about the HPFP failures. It seems virtually all of them are being covered unless there is a severe maintenance issue. Buying your diesel fuel at truck stops and high volume diesel stations seems to be the requirement here ... water and contaminants in the fuel from mom & pop stations is detrimental.
If you are looking for a 2014, you should wait. If money is no object, the 2015's will have a larger single-sided turbo, corresponding injectors and a switch-activated exhaust brake .... 425hp/875ft-lbs. is rumored. If money is an object, wait until the 2015's come out .... Ford will be giving away their 2014's. I just read the 2015's will begin going into production March 2014 for a Spring release. I just got a smoking deal on a left over 2013 plus 1.9% 72 month financing .... I just may look at a 2014 F350 Platinum which is what I really wanted.
White 2016 Work & Play Ultra 25ULA, Cherry Wood, Pebble, Onboard Onan 5.5, Onboard Fuel Station, 50-Amp Service
Onyx Black 2015 Chevrolet Silverado 2500HD DCSB, 6.6 Duramax/Allison, LTZ/Z71 397bhp/765t
Shadow Black 2016 Ford Mustang GT Premium Convertible 435 bhp (Wife's Toy)
Merlot Sunglo 2011 Harley Davidson Street Glide FLHX, FM 107", PM Heathens 21"/17", Metzeler ME880's (200 Rear), 115rwhp/124rwt
BrianSF-GA is offline   Reply With Quote
Old 01-10-2014, 10:11 AM   #35
What kind of hit is resale value going to take when that truck is no longer under warranty? That was one of the deciding factors for me when I ditched my 6.7 recently. Ford covered gobs of warrant work on the 6.0 diesels, but you haven't been able to give one of those away for years now. Hopefully it doesn't materialize into a big debacle like the 6.0, but I wasn't willing to take that $12K bet.
Old 01-10-2014, 11:09 AM   #36
BrianSF-GA's Avatar
I don't plan keeping it past the warranty period and all vehicle manufacturers have issues with their products in one form or another. There are only three diesel truck manufacturers to choose from .... other than opinions, is one really better than another?
As far as resale, if I had paid the additional $9,500 for an identically equipped and priced (MSRP) Duramax, I would be $9,500 in the hole to start off with. That additional money was the "entire out the door deal" which included the premium no other dealer matched for my trade, but for me, no matter how it's calculated, money is money.
Just curious, a previous post said you were glad you tried the 6.7 and now you said you ditched it. What did you trade it for?
Old 01-10-2014, 12:07 PM   #37
I was wondering how long it would be before someone brought up my September post!!! I was happy with the truck in general. It pulled great and man would it run. Got really good mileage as well. But, like I said, the fuel pump issues made up my mind. From my research, it seems to be a when and not if scenario. The fuel we have here just doesn't meet the viscosity requirements needed for the pump to survive. Just FYI, the Duramax uses the same pump- Bosch CP4.2. Dodge uses a different pump- don't remember model of it(CP3.1, maybe)- at a slightly lower pressure. I had warranty left on mine as well, but just because you get rid of it before the warranty expires doesn't mean you won't take a hit on value. The next guy coming up is gonna have to assume the risk that the fuel pump might go at some point. If he's aware of that and takes the potential $12K+/- hit into account, you will lose value. Like I said, maybe it won't pan out and it will be a non-issue, but I'll bet the guys that ditched their 6.0's early before it was common knowledge about the problems were glad they did. Also, there are claims out there that Ford is in fact dodging covering failures under warranty. Supposedly if they can find ANY rust anywhere in the system warranty is denied. I bought used- how would I know that filters were always changed when needed? Are the factory filters good enough to 100% guarantee that no water molecules will EVER get through? I didn't know and wasn't willing to take that risk. IF I experienced a HPFP failure that wasn't covered, it would be financially devastating. I'd have been making payments on a truck that just lost almost half it's value without the means to fix it. Not to mention we'd no longer have been able to camp. To answer your last question- I traded for a Ford F-150 Ecoboost.
Old 01-11-2014, 12:18 PM   #38
Ford 6.0
I have heard a lot of negative hype regarding the Ford 6.0. I know several guys with the later model 6.0s and they are quite happy with their trucks. I know them to be fairly dependable. Every manufacturer will have issues with new models or power plants that underwent major changes. Just visit the forums and you will find guys asking questions about the problems they are having with their trucks. This is especially true with the 6.7 Scorpion. It is a completely fresh, innovative design and the first diesel engine Ford has manufactured in quite some years.
At 11500 miles my late production 2012 has been rock solid so far. Knock on wood. One awesome truck.
The last thing I would say is that IMHO the torque and horse power numbers in the diesel engines today are all so close that it really does not make much difference if one can get up a hill a second or two faster than the other. It boils down to which model floats your boat. For me it is Ford. I am certain the engineers will work out the problems being discovered with the 6.7 models.
By the way, I read a few articles written by engineers from International that stated the problems with the 6.4 revolved around the EPA components they were forced to install. The articles pointed out the same engines sold in other countries that were non-compliant have proven to be solid motors. Of course, that is just what I read. No first hand knowledge of that.
Looking forward to this upcoming camping season. Happy Trails To All.
Old 01-11-2014, 12:48 PM   #39
Phat Phrog Stunt Crew
mackman1994's Avatar
Just turned a little over 14,000 on the clock on my late model 2012. As far as the 6.4 I think that the EPA components being the problem is a poor excuse because they should build their engines to account for the EPA components. I feel the 6.7 will be rock solid just like the 7.3 that Ford built. I believe the problems with the 6.0 and 6.4 was all Navistar.
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
Old 05-31-2014, 09:26 AM   #40
turnerpa's Avatar
Just an update on this motor, I turned over 25,000 miles last night and have yet to have a single problem or issue with the motor or truck. It is a 2013 f-250. Just thought I would share an update from quite a few hard driven miles in a short time frame for this motor!
