Old 06-01-2014, 02:24 AM   #41
Incheon, S. Korea
BigBaron's Avatar
Did you buy a motor and put it in, or buy a truck with the motor? Your first post is confusing, but then again, I'm easily confused...
Me, Julie, Lil' Barry, Faith, and OSDs, Fang and Treaty
2003 Hyundai Starex (H1), 2012 Coachmen Clipper 126
I don't know when we'll be able to go camping again...
BigBaron is offline   Reply With Quote
Old 06-01-2014, 07:50 AM   #42
Oklahoma Proud
MillerTime's Avatar
I believe he said it was a 2013. So it came with the motor.
I would hate to try to swap that motor into something! Its TIGHT!
Millertime- Sabre Handler
Old 06-01-2014, 04:17 PM   #43
Originally Posted by turnerpa View Post
Just an update on this motor, I turned over 25,000 miles last night and have yet to have a single problem or issue with the motor or truck. It is a 2013 f-250. Just thought I would share an update from quite a few hard driven miles in a short time frame for this motor!
Ditto! 21k and no issues. 5K of it towing camper. Totally satisfied.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 06-01-2014, 06:21 PM   #44
No doubt! I think I read they have to take the cab off the frame to do any major work on it. I swear if you laid underneath with the hood open you would not be able to see any light coming from the top. That under hood area is PACKED!
My new one:
ST Williamson
Current TV:'14 F350 Lariat CrewCab, 4x4 Short Bed SRW Diesel w/ Pullrite 2700 (16K)
Current
Fiver: '15 Puma 295BHSS Anniversary Edition
Past TV: '13 F150 HD Payload SCrew EB, '08 Tundra CrewMax 5.7L, '02 'Burb 5.3L, '97 Dakota 3.9L
Past Trailers: '09 Wildwood LE 27RB, '02 Palomino Yearling RL, '87 Jayco 1006dlx
campingwilliamsons is offline   Reply With Quote
Old 06-01-2014, 06:48 PM   #45
Phat Phrog Stunt Crew
mackman1994's Avatar
Love my Scorpion. Put 8000 miles on it in 9 days this winter 4000 or so towing over 12000 lbs. Have about 24000 total on her now with not one issue. Man what a truck!
Sent from my SCH-I545 using Forest River Forums mobile app
F-350 Lariat 6.7 Powerstroke
2014 Heritage Glen 356QBQ
mackman1994 is offline   Reply With Quote
Old 06-02-2014, 07:12 AM   #46
Dijoeboss's Avatar
Just before I left the Ford world 2 years ago, I had a 2012 6.7L tore all the way down to find a locked up crank shaft- they have tab-less main bearings and one of the bearings had spun and blocked the oil supply hole. Truck had 9,000 miles.
Dijoeboss is offline   Reply With Quote
Old 06-02-2014, 07:38 AM   #47
There must have been improper clearance on the crank pin. Tab brgs will spin also, had it happen on racing engines. For cam brgs, there is a groove in the block to allow oil into the journal regardless of the oil hole orientation. Sounds like that is not the case on the main brg caps of these engines.
Old 06-02-2014, 09:01 AM   #48
Dijoeboss's Avatar
Scorpion Engine
No, these engines have an oil hole like the 7.3,6.0,6.4...n
Old 06-02-2014, 09:39 AM   #49
Dijoeboss's Avatar
Scorpion Engine
Name:	ImageUploadedByForest River Forums1401719957.878917.jpg
Old 06-02-2014, 09:41 AM   #50
Dijoeboss's Avatar
Name:	ImageUploadedByForest River Forums1401720053.037226.jpg
ID:	54120Click image for larger version
Name:	ImageUploadedByForest River Forums1401720068.377102.jpg
